Saturday,30,September,2017,13:16:26:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86 VCDS Version: 15.7.0.2 Data version: 20150820 www.Ross-Tech.com VIN: WAUZZZ4E65N002074 License Plate: T22KRL Mileage: 187180km-116308mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1D 1E 25 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 66 67 72 76 77 VIN: WAUZZZ4E65N002074 Mileage: 187180km-116308miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Malfunction 0010 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: Malfunction 0010 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 66-Seat, Rear -- Status: Cannot be reached 1100 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 07C-910-018-BHT1.lbl Part No SW: 4E0 910 018 HW: 4E0 906 018 Component: 6.0L W12/4V A ª0110 Revision: -------- Serial number: AUX3Z0D4341645 Coding: 0011773 Shop #: WSC 00353 210 62620 VCID: 5C52777F5F24D7F2F9A6A1-8008 No fault code found. Readiness: 0000 1000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 J HW: 09E 927 156 A Component: AG6 09E 6,0L4V RdW 0060 Revision: 00000001 Serial number: 0037043 Coding: 0000001 Shop #: WSC 00353 210 62620 VCID: 2ABEE1A745F07942BB9A87-807E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 C HW: 4E0 614 517 BD Component: ESP 5.7 allrad H44 0330 Coding: 0007637 Shop #: WSC 12345 000 00000 VCID: 23A00C8322DAA80AF85CD2-8076 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 C Component: FBS AUDID3 H03 0140 Revision: 01403903 Serial number: AUX3Z0D4341645 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 585A6B6F2B1C3BD2DD4E9D-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 3 Faults Found: 00179 - Access/Start Authorization Antenna; Drivers Side (R134) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 30 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 00180 - Access/Start Authorization Antenna; Passenger Side (R135) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 4 Fault Frequency: 1 Reset counter: 72 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 00182 - Luggage Compartment Access/Start Authorization Antenna (R137) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 30 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H01 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063968 Shop #: WSC 00000 785 00200 VCID: 24A20F9F27D4AF328156D9-8070 2 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 32 Mileage: 186272 km Time Indication: 0 Date: 2017.07.03 Time: 01:14:26 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 40 Mileage: 0 km Time Indication: 0 Date: 2005.01.01 Time: 00:00:00 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300FF047536342 Coding: 0000002 Shop #: WSC 00353 210 62620 VCID: 3A9ED1E7B550C9C2CB7AD7-806E Subsystem 1 - Part No: 4E0 910 609 A Component: Bedienteil MMI H42 0020 Subsystem 2 - Serial number: 318EG047506302 Subsystem 3 - Serial number: 7405.05.040000000000010069ÿ Subsystem 4 - Serial number: 010069ÿ 2 Faults Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 31 Mileage: 187177 km Time Indication: 0 Date: 2017.09.30 Time: 11:02:00 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 4 Reset counter: 32 Mileage: 187181 km Time Indication: 0 Date: 2017.09.30 Time: 11:11:07 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 A HW: 4E0 820 043 A Component: KLIMAAUTOMAT 016 0300 Revision: 00000025 Serial number: 00000000046407 Coding: 0389369 Shop #: WSC 02311 785 00200 VCID: 1BD034631AAA90CA302C7A-804E 4 Faults Found: 01855 - Temperature Sensor for Heated Seat; Left Front (G344) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 30 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 20:01:56 Freeze Frame: Temperature: 20.0°C 01856 - Temperature Sensor for Heated Seat; Front Right (G345) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 30 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 20:01:56 Freeze Frame: Temperature: 20.0°C 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 13 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.28 Time: 17:44:22 Freeze Frame: Voltage: 12.70 V 01854 - Heated Seat; Front Right (Z46) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 69 Mileage: 187127 km Time Indication: 0 Date: 2017.09.29 Time: 10:31:19 Freeze Frame: Temperature: 14.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 J HW: 4E2 955 113 B Component: ILM Fahrer H12 0190 Coding: 0133121 Shop #: WSC 02313 785 00200 VCID: 2F88F0B37E121C6A6CE45E-807A Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0040 Coding: 00141886 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 Component: CD-Changer H43 0470 Revision: 00000000 Serial number: AUZ5ZBC1015724 Shop #: WSC 00000 000 00000 VCID: 1CD2377F1FA497F2392661-8048 1 Fault Found: 02084 - Component Protection 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 4 Fault Frequency: 254 Reset counter: 119 Mileage: 275443 km Time Indication: 0 Date: 2017.03.02 Time: 17:53:11 ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 C HW: 4E0 035 563 Component: DAB-Tuner H41 0830 Revision: 00000001 Serial number: KE1276W7101465 Coding: 0000001 Shop #: WSC 02152 785 00200 VCID: 24A20F9F27D4AF328156D9-8070 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: 07C-910-018-BHT2.lbl Part No SW: 4E0 910 018 HW: 4E0 906 018 Component: 6.0L W12/4V A ª0110 Revision: -------- Serial number: AUX3Z0D4341645 Coding: 0011773 Shop #: WSC 00353 210 62620 VCID: 5C52777F5F24D7F2F9A6A1-8008 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: None Part No SW: 4E0 910 561 F HW: 4E0 907 561 F Component: ABSTANDSREGELUNGH03 0020 Coding: 0041218 Shop #: WSC 02313 785 00200 VCID: 25A4129B2CEE563A9648CC-8070 2 Faults Found: 01517 - Control Module for Trailer/Towing Sensor (J345) 004 - No Signal/Communication - Intermittent - MIL ON Freeze Frame: Fault Status: 10110100 Fault Priority: 5 Fault Frequency: 5 Reset counter: 71 Mileage: 187176 km Time Indication: 0 Date: 2017.09.30 Time: 00:44:00 Freeze Frame: Temperature: 20.0°C Voltage: 12.67 V Bin. Bits: 00100000 01044 - Control Module Incorrectly Coded 000 - - - MIL ON Freeze Frame: Fault Status: 11110000 Fault Priority: 5 Fault Frequency: 6 Reset counter: 32 Mileage: 187176 km Time Indication: 0 Date: 2017.09.30 Time: 11:01:00 Freeze Frame: Temperature: 18.0°C Voltage: 11.14 V Bin. Bits: 00100000 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 G Component: Airbag 8.4E+ H10 0940 Coding: 0430707 Shop #: WSC 02313 785 00200 VCID: 63204C83625AE80AB8DC12-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112151 Shop #: WSC 02311 785 00200 VCID: 6524529B6C6E963A56C80C-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H04 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 931 E HW: 4E0 920 931 E Component: KOMBIINSTR. VDO H70 0400 Revision: D01 Serial number: AUDID3E5000168 Coding: 0032443 Shop #: WSC 00999 444 64523 VCID: 25A4129B2CEE563A9648CC-8070 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 HW: 4E0 907 468 B Component: Gateway H07 0070 Revision: 07 Serial number: 15004048120502 Coding: FEFFFFFC3B7D04 Shop #: WSC 00720 210 86425 VCID: 6524529B6C6E963A56C80C-8030 1 Fault Found: 00462 - Control Module for Seat Memory; Rear (J522) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 42 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 19:35:57 ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 A HW: 4E2 905 218 B Component: FPI_1 H01 0010 Revision: 01000101 Serial number: 11042005084300 Shop #: WSC 00000 000 00000 VCID: 1FA800730EB28CEADC040E-804A 2 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 0 Reset counter: 30 Mileage: 187120 km Time Indication: 0 Date: 2017.09.27 Time: 20:03:40 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 0 Reset counter: 70 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:31:32 ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2BB0E4A34A0AA04A408C8A-807E No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 C Component: FBS AUDID3 H03 0140 Revision: 01403903 Serial number: AUX3Z0D4341645 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 585A6B6F2B1C3BD2DD4E9D-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 3 Faults Found: 00179 - Access/Start Authorization Antenna; Drivers Side (R134) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 30 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 00180 - Access/Start Authorization Antenna; Passenger Side (R135) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 2 Reset counter: 32 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 00182 - Luggage Compartment Access/Start Authorization Antenna (R137) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 30 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 B Component: KLIMA-STG. FOND 015 0220 Revision: 00000018 Serial number: 00000000026849 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 612C468B7846FA1AAAF078-8034 2 Faults Found: 02291 - Control Module for Seat Vent; Rear; Driver Side (J674) 004 - No Signal/Communication 02292 - Control Module for Seat Vent; Rear Passenger Side (J675) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 00353 210 89229 VCID: 28BA1BAF5BFC4B52ADAEED-807C No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H01 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063982 Shop #: WSC 00000 785 00200 VCID: 24A20F9F27D4AF328156D9-8070 1 Fault Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 32 Mileage: 186272 km Time Indication: 0 Date: 2017.07.04 Time: 00:30:41 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H43 1060 Revision: 00000000 Serial number: 353FY047523897 Shop #: WSC 02313 785 00200 VCID: 3B90D4E3BA6AF0CAD06CDA-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H02 0090 Serial number: 00000413900087 Coding: 0036070 Shop #: WSC 02313 785 00200 VCID: 1DD43A7B04BE9EFACE1814-8048 2 Faults Found: 00211 - Control Circuit for Rear Illumination Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 2 Reset counter: 28 Mileage: 187104 km Time Indication: 0 Date: 2017.09.23 Time: 00:55:00 02138 - Control Circuit for Front Right Interior Lights 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 0 Fault Frequency: 3 Reset counter: 71 Mileage: 187124 km Time Indication: 0 Date: 2017.09.28 Time: 17:44:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: Türsteuer.FS BRMH01 0060 Coding: 0032751 Shop #: WSC 02311 785 00200 VCID: 20AA038F33CCB312E57E35-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H04 0040 Revision: 00400004 Serial number: W040406080130 Coding: 0004857 Shop #: WSC 02313 785 00200 VCID: 27B8189356E2442AA4B4E6-8072 Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H03 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0460 Revision: PROD_01 Serial number: 00000000003257 Coding: 0000017 Shop #: WSC 02313 785 00200 VCID: 2ABEE1A745F07942BB9A87-807E No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000042258 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1ED63D7709B885E2D7121B-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: Türsteuer.BF BRMH01 0060 Coding: 0032751 Shop #: WSC 02311 785 00200 VCID: 20AA038F33CCB312E57E35-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000631 Shop #: WSC 00999 444 64523 VCID: 1DD43A7B04BE9EFACE1814-8048 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0040 Revision: 00000001 Serial number: Coding: 0000003 Shop #: WSC 02311 785 00200 VCID: 622E49877D40E102B3EA6F-8036 1 Fault Found: 02235 - Stationary Cornering Lamp (Left) (M51) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 4 Fault Frequency: 1 Reset counter: 70 Mileage: 187128 km Time Indication: 0 Date: 2017.09.27 Time: 19:20:35 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 B Component: TUNER EU/US/RDW H41 0630 Revision: 00000000 Serial number: 304FS047595508 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 318CF6CB68260A9A7AD048-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 D HW: 4E0 919 148 Component: R0078 TVhybridTuner 0440 Revision: R0H06000 Serial number: 76300800403102 Coding: 0000303 Shop #: WSC 31414 790 00001 VCID: 24A20F9F27D4AF328156D9-8070 4 Faults Found: 00863 - Antenna 1 for TV (R55) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 5 Fault Frequency: 21 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 19:48:33 00864 - Antenna 2 for TV (R56) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 5 Fault Frequency: 20 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 19:48:31 00865 - Antenna 3 for TV (R57) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 5 Fault Frequency: 19 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 19:48:31 00866 - Antenna 4 for TV (R58) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 5 Fault Frequency: 21 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 19:48:31 ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H11 0510 Revision: 00000000 Serial number: 00000000002193 Shop #: WSC 00353 210 62620 VCID: 20AA038F33CCB312E57E35-8074 Subsystem 1 - Part No: 000 915 105 DL Component: von VA0 350117H281 Coding: 303030393135313035444C56413033353031313748323831 Shop #: WSC 12345 128 00289 5 Faults Found: 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 255 Time Indication: 0 Date: 2017.09.30 Time: 01:39:22 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 187177 km Time Indication: 0 Date: 2017.09.30 Time: 01:58:26 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 187177 km Time Indication: 0 Date: 2017.09.30 Time: 01:58:36 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 187177 km Time Indication: 0 Date: 2017.09.30 Time: 01:58:46 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 71 Mileage: 187177 km Time Indication: 0 Date: 2017.09.30 Time: 07:56:31 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM002 0060 Coding: 0032751 Shop #: WSC 02311 785 00200 VCID: 1ED63D7709B885E2D7121B-804A 3 Faults Found: 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 221 Mileage: 187104 km Time Indication: 0 Date: 2017.09.08 Time: 10:47:56 02130 - Interior Door Lighting 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 14 Reset counter: 72 Mileage: 187104 km Time Indication: 0 Date: 2017.09.17 Time: 18:43:08 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 68 Mileage: 187104 km Time Indication: 0 Date: 2017.09.20 Time: 10:43:30 ------------------------------------------------------------------------------- Address 66: Seat, Rear Cannot be reached ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000403240081 Shop #: WSC 12336 024 394758 VCID: 3686C5D781482DA22F2203-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM002 0060 Coding: 0032751 Shop #: WSC 02311 785 00200 VCID: 1ED63D7709B885E2D7121B-804A 2 Faults Found: 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 221 Mileage: 187104 km Time Indication: 0 Date: 2017.09.08 Time: 10:47:56 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 68 Mileage: 187104 km Time Indication: 0 Date: 2017.09.20 Time: 10:43:30 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H12 0020 Revision: --.--.-- Serial number: 08730413301313 Coding: 0101108 Shop #: WSC 02313 785 00200 VCID: 21AC068B38C6BA1AEA7038-8074 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 K HW: 4E0 862 335 Component: Handyvorb2 H18 0950 Revision: 00000000 Serial number: 00000005025638 Coding: 0010900 Shop #: WSC 02335 758 00200 VCID: 2ABEE1A745F07942BB9A87-807E No fault code found. End-------------------------(Elapsed Time: 04:06)-------------------------- |
