Old 5th October 2017, 09:03 PM
Looking at those calipers it strikes me that calipers are very old school engineering. That's a hefty lump added to the unsprung part of the car, where every few grams saved will improve both ride and performance. There must be a better way.
In fact thinking about it there is... inboard brakes. I wonder why they've not been more widely adopted. Cooling and or packaging perhaps.
Apologies for the thread deviation
Old 5th October 2017, 09:16 PM
The unsprung weight on the 20" cars is just crazy. Not only do they have enormous heavy wheels, but they also have steel uprights which weigh 13Kg each to compound the problem. Add big steel discs and the calipers (these do at least have an alloy piston housing) and you've got the weight of a Polo engine at each corner! Its hardly going to help the vehicle dynamics overcome a quarter ton of engine in front of the front axle.
I think you're right on why inboard discs never caught on. They take up valuable room which could be used for people and things, whereas the space in the wheel is otherwise free.
Old 5th October 2017, 09:18 PM
Spanker's Avatar
Spanker Spanker is offline
Your ingenuity and determination to find solutions to the problems amazes me
Drilling out snapped bolts with a tool to create a perfect guide hole for a larger bit, then creating a mini piston in a very tight spot to push out an ABS sensor! Bravo!
And then doing that when most people are snuggling up on the sofa watching the evening tele
Dean
Old 6th October 2017, 11:18 AM
MJ your talent is wasted in your day job, your problem solving and engineering is impressive. Put most men to shame.
Old 6th October 2017, 11:33 AM
+1 to what Dean said, although he did miss out on the other crucial job MJ is doing as well, and that is finding the time to photograph and document what she's doing.
Old 6th October 2017, 11:40 AM
Is Botang's Hole on the to do list MJ? Should be easy with the electrics out
Old 6th October 2017, 11:42 AM
Botang's hole is done That's how I discovered the wiper mechanism was worn out.
Old 6th October 2017, 11:52 AM
I should have known you'd have it sorted!
Old 6th October 2017, 05:50 PM
amazing work Michaela what cleaning products and methods are you using on the alloy parts? anything i try is useless or to harsh. Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 6th October 2017, 10:07 PM
I wonder how many people actually know Botang, or can put a first name to him. I bet he's no idea of his fame !!
