Old 14th December 2017, 04:44 PM
My PF D3 did the same in the cold, you need to make sure the wash concentrate is strong enough, otherwise it freezes in the pipe, and pops the connector off with the pressure.
Old 15th December 2017, 10:30 AM
erubus erubus is offline
Part of the reason I think there might be a split pipe or something else more broken-y. If the hose had popped off altogether I wouldn't have any headlamp washers at all. They work great though, just the fluid constantly leaks.
I have been too busy to get the thing apart to have a look at it so far. I've finally relented and decided to put heating in my house. Ive actually switched the fridge off because the kitchen is colder (average 3 degrees). I have most of the pipes in, the boiler is in place just have to connect up a few more radiators and do a bit more pipework under the floor.
After that I need to fix the Land Rover so I can tow a trailer without getting stopped (trailer light socket doesnt work), sort the radiator panel which has dropped making the fan hit off the cowling,then go and pick up an oil tank then get all that connected up and commission it. I have been told by the MIL that it needs to be up and running before christmas when she comes to stay for a couple of days. I'm not entirely sure Ive ever been forgiven for expecting her to sleep in a room that was below freezing!
Daily drive: 2008 A8 4.2TDi
2003 A8 4.0TDi. 4 zone climate, double glazing, Bose - dead
Other cars: 1980 Land Rover Series 3, 2.25d, hydraulic winch,Van/station wagon/topless depending on my mood
1990 Land Rover 90 factory county station wagon with all the luxury additions, such as a clock and a tape player.
2007 A4 3.0TDi s-line cabriolet quattro
2000 A8 D2 2.8 quattro, looking for a new home - gone
2003 A6 3.0 quattro, in the way... anyone want any parts? - gone
Old 24th April 2018, 01:39 PM
Rick Rick is offline
Late to this i know but here are pics of mine. Simple split pipe just where it bends to go to the washer jet.. Been leaking for 2 years but just sorted it. Took 10 mins.
ID:	18582   Click image for larger version
2006 S8 5.2 V10
Old 16th June 2021, 05:51 PM
dangerdred dangerdred is offline
and...even later to this...I had been noticing a wet patch behind the OS front wheel for a while now and the washer fluid level needing top-up not long after previous top-up. I pulled driver side foglight grill and found split in the pipe feeding the OS headlight washer that didn't take much to break completely. That said, there was no water coming out of either side headlight washer. I'm after buying a whole new piece of piping that feeds the headlight washers on either side and contains the T-piece connector to connect to the main feed - 4E0 955 974 AB. Will go at fitting it tomorrow.
Phantom Black 2008 A8 3.0 TDI SE ASB
Old 20th June 2021, 10:19 AM
I fitted the new section of corrugated piping for the headlight washers but I still have the same leak. It's behind the OS front wheel, and in anything I've read I'm lead to believe that this can be due to a leak at the front travelling along the undertray and depositing behind the front wheel - the main problem I have with this is I don't have an engine undertray fitted. I've noticed that it's leaking regardless of me using any of the washers. Can anyone point me to where I should be looking next, and does the fact that it's leaking constantly mean that it's the water bottle itself or else the feed from the bottle to the pump?
Old 20th June 2021, 12:09 PM
The water reservoir itself is hidden behind the OS front wheel arch liner, so that might be the culprit.
Old 20th June 2021, 07:51 PM
Ah yes, thanks. I've done a bit more reading and see the pumps themselves leak which I'm suspecting is my issue.
I've only just had it all back together after replacing the front upper suspension arms so now have to back in there again!
