Old 31st March 2018, 01:44 PM
Probably depends entirely on how long they spend going lockstop-to-lockstop and driving it about to remove air from the system. When the fitters are 'encouraged' to get a car out of the workshop ASAP it makes sense (to them!) to do the minimum. get the owner to do the donkey-work and then finish the job when it comes back....
Old 31st March 2018, 10:46 PM
27litres's Avatar
27litres 27litres is offline
They should be able to fill a power steering system like a brake system, using vacuum.
I mean, they're not going to give you your car back after a master cylinder or ABS actuator replacement and say "here you go mate. Drive it round for a couple of weeks, and don't forget to pump that middle pedal a few times eh. When you come back we'll get rid of any air left in the system. Any failures, come and see us"!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 1st April 2018, 07:37 AM
Unless Audi power steering systems have fundamentally changed since 2005, they are self-bleeding simply by using it. I'll be re-filling the system on Neil's 3.7 in about an hour after a rack swap yesterday and all it needs is to swing the steering from side to side 3-4 times and it will purge any air out on its own. Conceivably it could require a top-up in after driving it home, but there's nothing to do after that.
Old 1st April 2018, 07:48 AM
Thanks for that MJ, I thought I'd read something like that ages ago which is why I posted the question here.
Does make you wonder what on earth they did and why it went wrong after a couple of weeks?
Old 1st April 2018, 12:33 PM
I hope Neil is paying you well in chocolate eggs for having to work on Easter day
Old 1st April 2018, 02:51 PM
Neil definitely didn't skimp on the chocolate We finished about an hour ago so Neil is on his way home and I am stuffing my face
It was just 3 turns lock to lock to bleed the system btw.
Old 2nd April 2018, 10:22 AM
The chocolate was fine, it was all the crisps, pies and biscuits that Mike ate which nearly bankrupted me!!
Old 2nd April 2018, 03:03 PM
You should have tied one of his arms behind his back. That would have slowed him down... a bit
Old 2nd April 2018, 04:05 PM
I always understood that it was the aftermath of the curries that you had to beware.
Old 8th April 2018, 11:40 AM
And now it's gone wrong again, on a Sunday morning. My son is livid!
Basically he was doing a 3-point turn and it froze (lost assistance) while on full lock. Managed to get back home and onto his drive.
I've talked him through checking the reservoir - seems to actually be above max! He says there's a lot of fluid around it, so maybe they overfilled it?
I've also suggested he tries the lock-to-lock process a few times, probably while moving slowly as he has no assistance at present, to see if that changes anything.
He's now going to have a rant at Chingford Audi, who are allegedly there (probably only in sales though) to 4pm today.
