Old 21st July 2019, 09:20 PM
Erm, late to the party sorry. The V6 doesn't have the round separator pod that the V8 does.
The V6 breather system has some fragile plastic pipes which join the two cam covers to the throttle body. The plastic breaks, often in several places, meaning there's no vacuum in the crank case hence why the V6 leaks oil like the Deepwater Horizon. There's a separator in the gubbins down by the throttle body boot IIRC, and a few more plastic pipes. Other than the main pipe on the top, the rest are a total arse to get to. The manifold has to come off really. The packaging on the V6 round there is pretty awful.
Old 22nd July 2019, 08:09 AM
Originally Posted by hunker7 View Post
Are there any valves? Checked pipes and can't see any cracks.
Engine is 2.8. I'm starting to feel bad now, I've asked MJ so many questions
Ooops, sorry I missed that.
Old 22nd July 2019, 09:46 AM
Two links you might want to check out. Neither relates directly to the 2.8 V6 in the Audi, but they are for a 2.8 V6 fitted in a Passat, so in theory, should be the same or very similar (but then we know that VAG never keep anything the same!). If nothing else, they will give you an idea of what you're looking for.
This first one is a diagnostic procedure for determining if you have a leak, and requires a pressure gauge and VCDS:
https://web.archive.org/web/20120412...leakhowto.html
The second one is a YouTube video showing replacement of the entire breather system:
https://www.youtube.com/watch?v=4_BVzgOb2rk
Old 22nd July 2019, 03:05 PM
hunker7 hunker7 is offline
Take the engine cover off and it's staring you in the face at the back in the middle.
You might need a Clic-R tool to get it off easily.
And yet again I assumed everyone had what I have! Mine is a 2.8
Old 22nd July 2019, 03:27 PM
Yes sorry, as noted just above, I missed that.
Old 23rd July 2019, 04:32 AM
Thanks again guys. The pipes I could get to are all good and not cracked. Next job might be getting inlet mani off and see what's what.
