Old 4th November 2019, 06:23 PM
I've seen 2G & 3G mentioned, but how about the 2G High as fitted to my 2007. My AMI powers a hard drive, does anyone know if that indicate it will power a bluetooth dongle?
All D3's were 2G high or 3G.
2G will power a hard drive, but wont power the bluetooth dongle in my experience....
Old 10th November 2019, 01:53 AM
dangerdred dangerdred is offline
I've bought this - quoted by Snapdragon a few posts back.
I have the glovebox out and was wondering - for powering the device with constant power, I've sourced an empty 12v on the fuseboard (at position 40 - Brake Servo??)- although there's only one side of the fuse connector there, so is it possible to buy a crimp connector that would go in the other side that I would then join together with the existing live side by putting in a fuse?
I was gonna bolt the -ve cable to the chassis - this is all to avoid splicing into the existing power going in the back of the CD changer as all that came with the installation kit were scotchblock connectors which seem to be too big for these small cables.
Phantom Black 2008 A8 3.0 TDI SE ASB
Old 10th November 2019, 11:14 AM
DailyMike DailyMike is offline
ScothLock connectors are TERRIBLE things. For the sake of a few bob, I'd recommend you get some heat shrink connectors and a decent set of crimps. You'll NOT regret it.
Kind regards,
DailyMike.
Current modes of transport:
2004 A8 4.0DTI Quattro
19"wheels; Silver; 109,000 miles; Been off the road for several years. Lotsa work to be done
[BSold with regret:]2002 A8 4.2 (40v) Quattro Sport, 18" QS wheels; Prins LPG[/b], Silver; Black leather; newly-refurbished wheels in Anthracite...pics to follow soon!
2000 P38 Range Rover Vogue 4.6 V8 LPG, Epsom Green, fully-rebuilt engine (Top-hat liners, new camshaft for better mid-range torque); New S/S sports exhaust...SOUNDS BRILLIANT!
2014 Mondraker TrakkerR; 29-er, 30-speed gear train; rise'n'fall saddle; Mountain bike...NOT a cart-horse!
"JONDOR" a 116' long, 17"6" beam Humber Barge, Built 1950, ex oil tanker, fully refurbished Gardner 6LXC engine for propulsion (one day); requires new marine gearbox; 2-cylinder Petter Diesel engine & 3-cylinder diesel auxilliary engines with 12/24v and 230/415v gensets
"JONDOR" is a slow-burn project, being converted to provide suitable accommodation for wheelchair users and their carer/family for short respite breaks. Currently moored on River Humber at Old Beverley Shipyard
SOLD***2006 LWB Ford Transit 2.4 Diesel, Luton Van; Tail-lift; leaking translucent roof SOLD***
Previous vehicles:
Far too many to list individually, but includes 2005 A8 D3 3.0TDI Quattro Sport; 2007 A6 3.0TDI Avant; 2005 A4 2.0 Avant; 2007 A3 2.0TDI; 7-off Citroens, Many Fords, Austin 1100 (my first car), Lotus 7, Rover SD1 3500; SAAB 9000i, SAAB 9000 turbo; BMW 530; another P38 Range Rover (the crap one with BMW 2500 diesel engine...wouldn't tow the skin off a rice-pudding! )
Daren't even mention the traumatic Morris Marina and Ital's....even an Austin Princess. Brain is now hurting somewhat, so giving up for now...
Old 10th November 2019, 05:58 PM
Finished the install today with a fuse tap into the horn. I now have A2DP bluetooth streaming, aux, and microSD card. Just the glove box to put back in now which I'm not looking forward to...
Old 10th November 2019, 07:08 PM
Nice, please report back on your findings - I am tempted to have one for Christmas.
Old 12th November 2019, 07:50 PM
I only just noticed what rSAP was doing to my SIM card - my first thought was my phone had a fault until I realised I was losing the SIM when only in the car. So I've set the car pairing to phone call only with no rSAP and then also paired with the MrVolt device for media. All was good with streaming through the media device until I took a phonecall. The music muted and the MMI took over to handle the call. When the call finished the music came back up on the MMI screen but there was no sound. It seems the MMI is not relinquishing the audio back to the media device after the call finishes.I'll have to investigate further. Another possibility I can explore is to let the media device handle the calls as well - I'd need to wire in the included mic.
Old 16th November 2019, 07:20 AM
Did you disable the Handfree feature of the media streaming device?
Does the music still show as playing or paused on the phone screen?
Old 16th November 2019, 07:34 PM
I have the handsfree part of the device disabled. Media device has been erratic, with my original issue no longer happening and streaming audio is returning after finishing phonecalls. The device does not always autopair when I sit into the car though. I ran a scan and got...
Address 0E: Media Player 1
Cannot be reached
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B081308038
Coding: F5F99F7F507A0E00
Shop #: WSC 11111 123 12345
VCID: 2D070AA14117892F521-8078
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 64
Mileage: 211271 km
Time Indication: 0
Date: 2019.11.16
Time: 15:21:35
I'm presuming the gateway is wondering what's this new device on the network. Does anyone know what I need to code to get the new device accepted onto the network, or is it that I have the new device in the wrong location on the MOST bus? If I check the Gateway installation list in VCDS, Media Player1 is unchecked in the list...
The current media addresses are listed...
0E-Media Player 1 -- Status: Not registered 0001
0F-Digital Radio -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
Old 22nd November 2019, 05:07 PM
I had the same thing when I fitted an mp3 changer beside my original CD changer in the glovebox. The trick was to tell the second CD changer that it should assume a different network address (I think CANbus not MOSTbus address).
It was to jump two pins on it's connector - one spare pin was shorted to ground. I will try and find it. I am not saying this will fix your issue but is a good place to focus.
Old 23rd November 2019, 12:45 AM
I've managed to get the device accepted by the Gateway and onto the network with no faults showing. The only thing I have now in VCDS is that Media Player 1 'Cannot be reached' - but it doesn't throw an error.
The device is working OK although it could be more seamless e.g. I often have to manually start up whatever streaming app I had been previously listening to when returning to the car whereas, with other bluetooth head units, the device will automatically resume the bluetooth stream without any user input. It also doesn't always autoconnect when I get into the car so I have to take out my phone and manually connect. It does switch between stream and USB well, but SDcard seems to takeover completely when inserted, where nothing else can be selected,and often the SDcard itself doesn't play. I haven't tested the aux input and probably will have no need for it anyway as long as the bluetooth is working. Over all I'm happy to have expanded the capabilities of what was originally there.
