Old 27th December 2019, 09:25 AM
RPM: 630 /min
Voltage: 13.53 V
Does it idle at 630rpm, or is that the cranking speed during starting?
It looks like there are missing CANBUS messages at this time the codes are set - some of the messages are telling dash illumination to come on etc...
If this happens again, can you manually turn the healights on and off a few times with pauses in between as this will send the illumination messages again.
I would think a low battery would cause this but the freeze frame voltage shown is good, but was this voltage perhaps after the engine started (630rpm)
Old 27th December 2019, 01:41 PM
The first thing I'd suggest you do is clear all the codes, as some date back to 2003. Once cleared, go for a drive (leave overnight if necessary to reproduce symptoms) and then scan again. Post that scan and go from there.
With regards to the current scan, I'd say it's possible a faulty connection on the instrument cluster, or, since both engine and ABS modules are throwing errors, then (if the same errors reappear), check the physical connections to these ECUs for water ingress, both of which are in the plenum chamber, and open to the elements.
Also pop along to the Introductions page and introduce yourself. We also have an affinity for photos, so brownie points on offer there.
