Old 10th January 2020, 11:00 AM
Not familiar with the D4, but would suspect the setup is very similar to the D3. With that being the case, I would initially rule out both rear air struts as being the problem (what are the chances of both developing a fault at the same time), and instead focus on the valve block as being the primary culprit. It could then either be a leak from the valve block or something internal. Spray on some soapy water, run the car and check for leaks. You could try spraying the struts as well, if it's easy to do.
