How complicated is wiring for auto dimming rear view mirror? My 'manual' fell apart, thinking of fitting auto dimming if it's not overly complicated?
To do it properly needs a donor car from which to extract the wiring harness, and requires the headlining out. It has 6 connections to other circuits, comprising side lights, reverse lights, switched and permanent ignition, output to the side mirrors and ground.
However, people have managed to wire it in to just the stuff thats already up there for the interior lights and sunroof and gone without the side mirrors (megabucks anyway) and the disable-in-reverse feature. I think Andrew has done that, maybe someone else too? There was some discussion about it in AdrianE's sale thread for his spare platinum mirror. |
There is a thread relating to retrofitting one of these, which is useful:
http://forum.a8parts.co.uk/showthread.php?t=1100 The only issue I ran into when doing mine was the colour of the wires being different to mine. In the end I just used the pin assignments to get the power, and as MJ mentioned, just wired it up to get the mirror working. This one post from my own thread may be useful in regard to sourcing power for it: http://forum.a8parts.co.uk/showpost....0&postcount=10
Only on my PF and as described I didn't bother with the external mirrors. Pretty simple to do.
Funnily enough my FL one had it factory-fitted and the internal mirror is still fine after 18 years, but the external mirrors failed long ago. I managed to procure them individually though it took some time, so it does now work correctly even though I personally don't feel the need for the external ones, other than OCD of course…... The drivers side is actually as US passenger one with the silly wording on; doesn't bother me. ![]()
Objects in the mirror are losing
Great, thanks guys. Seems simple enough, even with reverse feed.
It was so long ago I forget the details, but I also did a similar install on the Ford Focus I had at the same time, both mirrors had effectively the same connections.
IIRC I tested the mirrors off the car by hooking up a 12V power supply, this also verified the actual connections. The reverse signal I personally found pointless, but if you want to use it there's a long circuit that runs right through the car (via the F125 switch!) to the reversing lights. One convenient access point is the back of the RNS where I think it's labelled something like RFSL and is red/blue possibly brown? I think I recorded what I did in the thread linked to above by Sean (Steamship).
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 12th July 2020 at 09:57 AM. |
