Old 26th February 2021, 09:20 PM
Originally Posted by Echo View Post
No rear stuff in there I'm afraid.
So, I put in: 0001003
If you don't have RSE then the code would be 0000003.
Also, do the antenna outputs look ok?
Number 4 seems a bit iffy.
Did VCDS throw up an error for antenna 4? Just curious since the output test shows it as 'deactivated'.
BTW The part you have; 4E0910148C; is fine. The A8 will accept A,B,C and E.
