Check the plastic tube on the top of the pan for leaks where the wiring harness goes in. This sleeve seal is common for all ZF leaks. In addition, you may want to order the 4 rubber tube seals and the bridge seal and have them changed when you service the box. These seals can leak fluid internally and cause the gearbox some issues
The sleeve seal leaks externally and the ZF box doesn’t enjoy low fluid at all. The ZF 6HP26 is capable of operating the solenoids to overcome internal and external fluid leaks and therefore pressure changes. So once repaired, simply reset the adaptation for the solenoids. Google ZF 6HP26 seal and it will come up with many things. Otherwise these boxes are pretty bulletproof
04 A8 - 4.2 Sport Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension Auto Boot - Double Glazing - AMI - Solar roof TV - Bose - Voice Control - TPMS - AFS- TINT Power Blind, Fingerprint - Light package (in and out) Retrofits: OEM Auto headlights & rain sensing wipers OEM Bluetooth phone Bluetooth Audio Streaming Reverse Camera OEM Aluminium Package Auto boot close using remote/door button |
