Old 5th April 2021, 12:49 PM
mcs's Avatar
mcs mcs is offline
I had my gearbox serviced and asked for the 4 rubber tubes and the bridge seal to be changed. The place did a pan gasket and a fluid flush then gave the car back.
The pan then began leaking so I sent my car in to have another pan gasket and this time gave the place the 4 tube seals and the bridge seal which I ordered myself from ZF in germany. They tightened some bolts and gave the car back again. I have ZERO tolerance for idiot places who do not listen to specific instructions.
Consequently my car is still leaking and will be going to a ZF specialist on the 12th. It will have an adaptation reset as well as every seal changed. I will report back on how this cures slipping.
The solenoids adapt to low fluid or internal leaks so it should be back to brand new with fresh seals, fresh fluid (again). My car has 145,000 miles on it, and this would be its 3rd fluid change. (the first was ZF at 60,000 miles, the second was the idiots at 130,000 miles.
I will report back.
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 5th April 2021, 05:31 PM
homer simpson's Avatar
Which place are you taking it to?
Old 6th April 2021, 09:49 AM
Definitely NOT Mackies, that's for sure... based on his location 'down under'.
Old 6th April 2021, 11:40 AM
Ahh missed that, would be a bit of a long trip to use a UK specialist
I'm hopefully going to use the Cannock one in the summer
Old 6th April 2021, 12:43 PM
Which is maybe marginally closer for mcs, but still a very long drive!
Old 6th April 2021, 12:56 PM
mcs's Avatar
mcs mcs is offline
Our national anthem has "girt by sea" in it. Quattro is good but not that good. It is impossible to drive abroad.
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Reverse Camera
Old 5th April 2021, 05:33 PM
vajper vajper is offline
I'm really interested in your findings!
I took the car for a proper adaptation ride today. Followed the four separate adaptations in the SSP 385 and indeed, I got adaptation count for all clutches. It's quite fun when the documentation matches the real world -- was lacking adaptation on the clutch related going 1->2. After getting this in place, the shift was a lot smoother.
Unfortunately I still see slippage, especially on gear 1, 2 and 3. VCDS indicates torque converter is not locking until reaching higher gears. What I see though, is that the TC lock goes from Open to "Torq. conv. reg" in the slippage cases. EDIT: Removed some stuff. REG mode seems to be a valid mode where some slippage (max 512rpm?) is allowed to handle smaller throttle changes. So, instead of shifting up/down, it slips a bit. Something about being fuel efficient. Also something that seems to be a hazzle when pulling a trailer... Maybe this is as good as it gets?
Adaptation values are not out in the blue. Unfortunately I don't have the old values from before resetting the adaptation but as of now, no value is outside the limits. Still I'm thinking leaking seals may result in the TC lock not engaging.
Anyone with experience on this?
2005 A8 D3 4.2 TDI Engine: BVN, Gearbox: JEF, Colour: Z9Y Phantom black pearl effect, Interior: Amaretto brown with alcantara headliner
Old 6th April 2021, 01:12 PM
mcs's Avatar
mcs mcs is offline
I am told the gearbox does slip the clutchpacks on purpose to make it smooth. It is considered normal operations. The 4 tubes however, control the amount of fluid supplied to the clutchpacks I am told and they get hard as well as compress to leak fluid internally. This won't help things.
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Reverse Camera
Old 11th April 2021, 05:59 PM
I have ordered new rubber thingies, new gasket to the tray plus another seven precious liters of ZF LifeGuard 6. If I get all the parts for next weekend, I'll give it a try. After doing so, I will run through the four recommended steps in the SSP. I'll report back later...
Old 12th April 2021, 04:13 AM
mcs's Avatar
mcs mcs is offline
I just picked up the car from the gearbox place.
It is a totally different machine to drive. So smooth. Seriously smooth.
The rev hunting on the overrun has vanished. The gears downshifting are not noticeable as the car slows to a stop.
I was told the internal seals were incredibly worn, and this would cause many issues as the clutchpacks cannot get the correct fluid amounts due to internal leaking.
However, it is all done now. Recommend these parts are changed every 100,000 klms.
Mike
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Reverse Camera
