D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus |
Well I've left fitting the hardest component until last - the MMI Control unit in the rear armrest adjacent to the HVAC panel.
Why do I think this is the hardest? Purely because of the surrounding wood trim. In fact what I thought was a wooden top trim turned out to be a substantial aluminium casting with the wood bonded to the top. Not only does this have to be cut in exactly the right position and correct shape it also has to have a very clean, smooth cut as the panel does not have any overhang to hide rough edges. The chrome trim will butt up against the edge of the aperture and any and all defects will be clearly seen. There is also a thin transition piece that has to go between the MMI Control & HVAC panels which will not have any visible way of fixing because the MMI Control takes its locating holes & clips. This will have to be an interference fit to hold it in place. It looks like neither panel has a straight edge along its long length being slightly curved further compounding the fit. Both side trims will also have to be cut with the above proviso so may very well end up with new trim which even if I can find it available in Audi Exclusive Poplar Brown Silver will I guess be very expensive based upon other trim in the car such as wooden gear knob trim at nearly £300 and rear seat trims at £500 each. ![]() I'd reached the conclusion I had nothing to lose by attempting to cut the original because at best it might just work but at worst I will need new trim anyway. Worth a shot in my book. Here's the top trim removed to show the substantial construction making it difficult to cut; First of all I attacked the side trims with Mr. Dremel. This was done in two stages. Having taped up the side trims with masking tape and with the MMI Control panel dropped roughly in position albeit standing proud I used the lower outside of it to run round with a pen to mark the position, shape & contour of the unit to make my first cut allowing it to at least drop into to engage the fixings that will secure it in place. Bear in mind this is not the finished size as the chrome trim protrudes a little further but does follow the same shape/profile and will allow me to locate it properly into the armrest so I can mark around the chrome trim for the final cut to give me this; Close up of left cut. Close up of right. You can see where the Dremel rotary sanding mandrel popped out of the top corner ![]() Any suggestions on how I might remove/polish out those Dremel marks would be greatly appreciated. At least I have the offcuts to practice on before attacking the console itself. Then the most difficult part to date - how to cut the aluminium/wood top plate. Too much to Dremel, not enough control over an air die grinder or cordless grinder, too much hard work and lack of precision with a hacksaw. I have an Evolution Rage chop saw but have never used anything other than the supplied 24T Multi-purpose blade that cuts steel, aluminium, wood, plastic etc and I feared not achieving a clean enough cut. Something that is capable of cutting nails embedded in wood is probably not conducive to a nice finish! Had a look round and found an 80T aluminium/wood blade that sounded perfect for the job. I made a crude jig to hold the top trim out of a piece of wood with two grooves to locate the aluminium legs and three holes to accept corresponding protrusions on the bottom of the top trim. To mark the three holes I ran a piece of masking tape along the wood and pressed down on the trim with the legs in their corresponding grooves. Sure enough I was left with three clear indentations on the masking tape which I quickly opened up with a drill. Hey presto...a custom made jig! I popped the top trim back into place in the armrest, ran some more masking tape across it and marked in all four corners where the two cuts need to be to find my cutting lines. I then removed the whole trim for the last time and clamped it on to the bed of the chop saw. It was at this point I would have said a little prayer if I believed in God but I don't so I didn't and just went for it ![]() Result! A lovely clean cut followed by a little hand filing on the detached piece to achieve the slight curve and desired fit & finish. Not too shabby and just the thin transition piece between the two control units to cut now which was pretty much a mirror procedure; And Voila! Not perfect but then again I won't be staring at it as I'm in the driving seat but it's not holding anything else up and to be honest it looks like I have factory RSE even if it doesn't work yet! ![]() When I pop the MMI Control unit out to connect the wiring I intend to run some dark wood stain and/or polish in and around the edge of the aperture to disguise the edges a little more. I'm really disappointed that I slipped with the Dremel right at the final hurdle when polishing that corner out (it would probably have fitted OK as was) but it is what it is. My neighbour who was holding the hoover tube to suck up the dust while I was cutting recoiled in horror at the language that spouted from my lips! I will keep my eyes open for the proper trim at the right price at a time to suit me just to satisfy my OCD. If I was to sum up the job I would say "It went better than expected but not quite as well as I hoped" but overall I am glad I am pleased with the result even though if anyone asks me to do it on their car I would politely decline as I would be washing my hair that day! Just that wiring to do now when I am happy I know where everything goes and then I can switch on, setup and keep fingers crossed everything works! -=Glyn=- Last edited by GlynH; 17th October 2021 at 02:27 PM. |
