D2 - Sat Nav, ICE, Audio & TV All in car entertainment discussions |
https://www.kufatec.com/en/car-hifi/...-audi-vw-38717
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
All these bose adapter with big 'black boxes' have capacitors in them which get rid of the popping but also cut top end and low end of the sound by the nature of how they filter, so they dull the sound down terribly. Thats why I went with 2 period correct amps for the car a 4 channel for all the doors and a 2 channel for the rear subs, all can be controller by the dsp equaliser in the radio. The amps share the same ground as the rest of the car inc. the android radio so all those issues have gone away. Last edited by Ronin; 30th October 2021 at 05:20 PM. |
Which begs the question, actually, what would the RNS or Symphony sound like with decent aftermarket amp and speakers? An aftermarket dongle which can play FLAC through the cd changer port might actually yield decent results and look OE.
Hmm... |
Also the plastic finish/colour/surface is a perfect match with the climate control plastic so it looks perfect. The RNSE has a different finish so it always bugged me I started researching getting the right android .apk's to get the radio to display to FIS.. Getting dynamic reverse camera projection lines is also just a matter of making the radio read off the steering wheel angle sensor... I have all these ideas for the car but I keep it on a farm, im very limited in terms of what I can do because of Welsh wheather haha. I have also just bought another 2 din facelift stereo cage, I will use it to create a proper set of brackets to mount the radio perfectly in it with bolts and rivnuts. Currently it sits on about 6-7 layers of sound deadning matt which doesn't help the panel gaps between the radio and the fascia and cooling too. Once I have it down to perfection I will publish all the dimensions and sizes of everything. Last edited by Ronin; 30th October 2021 at 06:16 PM. |
https://youtu.be/3d8uIueD1K0
He is just projecting his phone onto the tiny grainy screen of the RNSD nothing special in my opinion. You can't control it with the physical buttons in the head unit. You can't even 'legally' answer a call as you have to touch the phone to do it.
I have bought another sterego cage from prestige to create all the appropiate bracketry..
The pictures below will also show how ill-fitting this 'dedicated' radio is.... I wish i had a 3d printer.. but i can probably just about manage with bits of MDF ![]() Currently the HU is sitting in the cage on layers upon layers of sound deadning mat - didn't have anything else to hand at the time... |
Managed to get the radio in perfectly.
To do this I removed the L shaped piece at the back (its rivetted so can be easily removed) ![]() Removed the plastic insert/guide: ![]() Screwed on a 17mm thick piece of skirting board in place where the L shape piece was: ![]() ![]() Attached 2x 1mm thick shims with double sided sticky tape at either side of the radio to perfectly center it: ![]() ![]() ...and job done: ![]() Last edited by Ronin; 5th November 2021 at 09:54 AM. |
