Old 14th May 2022, 07:51 PM
Audifan Audifan is offline
Default Jack stand location
Where is the best place to set the jack stands on these cars without doing damage? I want to lift up the front of the car and place jack stands underneath the car so I can remove both front wheels because this will help me remove the fasteners for the front bumper. I'm ready to do work on the engine and I need to put the front end in the service position so I have room to get my socket and wrench on the crank bolt so I can hand rotate the engine to do the valve spring replacement.
Old 14th May 2022, 08:14 PM
Ronin Ronin is offline
You can remove front bumper without doing that. Just remove the under tray if you have it, few clips holding the front wheel arch liners to the bumper and bumper itself is held with 2 Allen bolts located behind the grilles of the bumper
Old 14th May 2022, 08:29 PM
You can put them under the rear subframe mounting bolts. That's a good hard-point which will support the full weight. Don't use the subframe itself - that isn't strong enough.
Old 14th May 2022, 10:22 PM
My car doesn't have the under tray unfortunately. I only saw one plastic hold down (not sure what the correct name is) for the wheel arch liner. I'm sure there is more then one and I prefer to remove the wheels so I can see everything so I don't damage anything.
Ok but will it be safe to use since my jack stand has a u shape top? I found out the hard way to not support the subframe itself with the jack stand as it put a dent in it.
Old 15th May 2022, 07:24 AM
Stick a block of wood on it then. You don't really want the weight on the aluminium plate as thats not very strong, so the bolt head itself is best point.
Old 15th May 2022, 02:31 PM
I'll keep that in mind when I use the jack stands. I eventually want to buy these jack stands to replace the ones that I have.
Old 15th May 2022, 02:42 PM
I didn't use my jack stands. I just used my floor jack to get the wheel off the ground and took off the wheel to remove the liner and reinstalled the wheel.
LH wheel arch liner has some damage. Anyone have the part number for this plastic fastener?
Missing hardware.
RH wheel arch liner damaged and missing hardware.
Name:	lh liner 1.jpg
ID:	28439   Click image for larger version
Name:	lh liner 2.jpg
ID:	28440   Click image for larger version
Name:	rh liner 1.jpg
ID:	28441   Click image for larger version
Name:	rh liner 2.jpg
ID:	28442   Click image for larger version
Name:	rh liner 3.jpg
Old 16th May 2022, 09:01 AM
The following image should help in identifying all the relevant fasteners required. Based on the image, these are the associated part numbers, and how many you require per side. Note that these totals are for both parts of the wheel arch liner on either side of the car, and not just the front part. I've also attached images of what the part numbers look like in reality.
And yes, part numbers 12 and 14 are the same. Must be an Audi thing!
#10 - 171201969 - Hexagon collar nut (8 per side)
#12 - N90250001 - oval head panel screw (2 per side)
#14 - N90250001 - oval head panel screw (1 per side)
#15 - 4D0807300 - Spreader rivet (4 per side)
#16 - 443821699 - Clip (2 per side)
#17 - 811807577C - insert nut (1 per side)
Name:	A8 D2 Wheel Arch Liner.png
ID:	28469   Click image for larger version
Name:	PN 171201969.jpg
ID:	28470   Click image for larger version
Name:	PN N90250001.jpg
ID:	28471   Click image for larger version
Name:	PN 4D0807300.jpg
ID:	28472   Click image for larger version
Name:	PN 443821699.jpg
ID:	28473   Click image for larger version
Name:	PN 811807577C.jpg
Old 16th May 2022, 08:04 PM
Thank you very much! My car is missing a lot of these fasteners and I will eventually buy new replacements.
