#51
because the gearbox has to come off again to fix this damn connector leaking. I've never had one of these leak before - sometimes they get a bit damp, but as soon as I plug the connector in, it starts making a puddle on the floor. These two o-rings are in a bad way I was thinking when I had Paul's FE in bits, I should probably add these o-rings to my routine, since they don't tend to leak but it'd be a right pain if they did and its easy with the sump off. Literally the next one through the door bites me on the **** with that exact problem ![]() I'm quite grumpy ![]() TPS have priority-ordered a pair of o-rings and a new sump gasket for me so this can go back together tomorrow and normal service had flippin' well better be resumed! ![]() |
#52
Oh dear.
![]() At least you have your wonderful separating machine, or it would presumably be a whole lot more aggravating. ![]()
#53
Could it be that on a prior service someone just wrenched on it a bit and 'broke the seal'. I remember noticing my connector on my 2.8 being oily and there was a temptation in my novice head to 'tighten it up a bit'.... but in the end I left alone as discovered it was engine oil coming from above, and the fact you told me so.
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
#54
I'm not sure why the connector is designed to float in the casing tbh. It would make a lot more sense to me for it to be tight in there and not move which would give the o-rings a much better chance of staying sealed. Just one of ZF's little easter eggs ![]() |
#55
I went out at lunchtime to fit the two o-rings and put the sump back on so the gasket sealant (blue Hylomar) can flash off before this evening when I'll want to flip the gearbox the right way up again and refill it
#56
Seeing this makes me want to do a manual swap for reliability purposes, especially for the german trip, but my day to day lazy and realistic side is telling me i would start to hate driving the car
#57
I prefer daily driving the Allroad to Big Red simply because of the gearbox. The auto ruins the 2.8 for me because it is so stupidly programmed. I'm not planning on taking a 5HP round Spa
![]() Not much to report on the thread this evening. I put the oil back in the gearbox and put the gearbox back on the separating machine. Its going to spend overnight with two bellhousing bolts in and the valve body connector connected and make sure there are no more leaks before I reattach the converter and starter etc etc. I pulled the power steering pipes off as they're pretty crusty. Hopefully I can get those off to the hydraulic shop tomorrow. |
#58
A good day today
![]() First pass of APC Sprayed with tar remover Rinsed down after a second pass with APC Nice and clean The other side was much the same Botang's hole needed attention, and since the interior is already out its pretty simple to take the electronics box out, and looking under here its a good job that I did! At some point in its life the water has got pretty high in here Botang's hole just hiding there under the AC pipe The source of the rust stains ![]() Hoovered out and there is an orange tide mark about 2" up I attacked it with Bilt Hamber Auto-wheel, which is a first for me in this area! It immediately got to work on the iron and turned a deep purple. Much better ![]() The blower motor is getting replaced with a D3 version which is made considerably easier with the ecu box out as well The D3 motor has a different connector D2 connector spliced on to the D3 blower Wrapped up |
#59
I've had some horrendous problems with the scuttle drains, the evidence is exposed above!
![]() What exactly is the very rusty component that is "nicht gerfingerpoken" and is NLA but you're thinking of a solution to? And what happens when it goes wrong? Quote:
![]() Presumably all a bit more comfortable to work on with no bonnet?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 21st May 2022 at 08:31 PM. |
#60
Very pleasant working with no bonnet
![]() The rusty lump is the water pump for the heater. Its built in to the side of the heater valve block and is supposed to push coolant through the two heater cores as the engine water pump doesn't have enough flow or pressure to get through the valve block. When the pump fails it just takes a while for the heater to heat up. Good working valve blocks with good working motors are unobtanium now so I plan to redesign it using parts from the C7 A6 which has separate valves and pump. They're newer, cheaper and smaller. It's just going to need some creative plumbing to stick it in the space where the D2 valve block goes. The drains are all clear now ![]() |
