Go Back   A8 Parts Forum > A8 D4 > D4 - Wheels and Tyres
D4 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here
Old 1st December 2022, 03:17 PM
The seat of the pants probably points to rear wheel issue - balancing or bent rim?
Old 1st December 2022, 03:45 PM
Do you know if they are the correct rims for the car? Specifically, does the centre bore match the hub, as this will cause a vibration at higher speeds?
As far as I know, I believe the CB on the D4s are 66.6mm, the D3s were 57.1mm, so if you had D3 rims on, then you'd get this vibration.
Old 1st December 2022, 03:55 PM
Saff Saff is offline
Thanks Steamship.
AFAIK they are the originals, 19 x9j 10 spoke Y. They fit snugly on the hub.
Old 1st December 2022, 04:32 PM
Flat spots on the tyres may also cause vibration.
Old 1st December 2022, 04:36 PM
OK thanks Conan. Rear tyres are new and the issue was there before but well worth a re-visit to the tyre dealer to check.
Old 1st December 2022, 05:03 PM
Are all tyres the same tread pattern? Though I ran a D2 on mismatched tyres and it went along no problems at all.
Runflats can be a nightmare, the ones on my 5 Series cause this when the obligatory sidewall bulge occurs around 100 miles after hitting the many potholes on the roads
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 1st December 2022, 05:52 PM
Hi Strummagnet, yep each axle set match
Old 1st December 2022, 03:48 PM
Thanks Paul. Yep I agree. I guess I could swap rears to front to see if the effect changes then that would narrow it right down?
I even thought about trying the space saver but that also may be away with the fairies balance wise plus I'm limited to 50 mph.
Old 1st December 2022, 05:13 PM
Swapping front to back would help isolate the issue for sure
Old 1st December 2022, 05:53 PM
