Old 8th December 2022, 11:38 AM
The only pics I could get of this stuff is either in the bin or on the workshop floor Better to go off the manuals
Unfortunately, I seem to thick to find the right page in the manuals
Old 8th December 2022, 12:03 PM
I can't find them either
Old 8th December 2022, 05:57 PM
Well, then there’s no hope for us mere mortals if the D2 Doctor can’t find them
Old 8th December 2022, 09:25 PM
Start from page 30 of the following PDF:
SSP 217 V8-5V Motor Audi.pdf
I think when I did mine, I followed the instructions at the following page:
http://www.audipages.com/Tech_Articl...sereplace.html
... and only replace one section at a time.
Old 10th December 2022, 02:18 PM
Thanks Sean. Is this what I should order to replace the hose?
https://www.ebay.co.uk/itm/COTTON-BR...edirect=mobile
Old 11th December 2022, 09:18 AM
That looks perfect. Admittedly, when I did mine many moons ago, I opted for blue silicone rubber... just to be different.
Old 22nd December 2022, 12:53 PM
This code usually happens because the brittle plastic pipe connecting the solenoid valve on top of the bank 2 fuel rail to the two SAI vacuum valves has perished and broken and so they aren't actuating on a cold start. The ECU can see they're not working by the readings from the secondary O2 sensors.
Its simple enough to fix by replacing the broken plastic pipe with standard 4mm braided vacuum hose and a T piece.
Well, she's spot on yet again (see photo below). And thanks to Sean as well for sending me the guide from Audipages.com. I only replaced the plastic pipes that Michaela mentioned as I couldn't get to the vacuum reservoirs without major (for me) dismantling work.
Started it up and the engine management light went away without even needing to clear it!
Old 22nd December 2022, 02:54 PM
That's the ones that failed for me, right at the back of the engine bay. The rubber pipes had gone brittle and were falling apart, and it was literally the braid holding it together.
Old 22nd December 2022, 06:18 PM
The pipes that I photographed were just plastic - not braided rubber (they are now though!). One had snapped. I re-used the T-connector and will replace the rest of the hoses as and when I need to, or when I have more stuff off the front end.
Old 22nd December 2022, 09:29 PM
Plastic is standard, but many of them have already been replaced by braided hose, probably multiple times.
