The link I provided in my last post (which is missing some important items which I will highlight here), doesn't state anything about this bracket for the front door cards.
Sorry that this isn't the best picture but the above picture of the bracket is for holding a wiring harness. After you get the lower door handle cover off, there is two little screws (already removed in this picture) that need to be removed and then there are two 8 mm bolts that needs to be removed. Once you remove the door card, you can pry up this large air tube so you can get the wires removed. I haven't figured out how to remove the round push pin without damaging it. This picture is from the front oxblood door card where the push pin is broken that holds the large air tube seen in the picture above. These retaining clips (with the red dot) needs to be removed in order to remove the wires. This memory seat switch needs to be removed. Then you need to remove the wire plug in order to push the wire through. This is the oxblood front door card with the wire plug removed.
2001 S8 (build date March 16th 2001) Brilliant black with oxblood red/black interior. Mods prior to my ownership: 01E 6 speed, carbon fiber trim, bi-xenon, aftermarket muffler with x-pipe, tinted windows, non-tip steering wheel, Spal electric fan. My mods: Oxblood red interior, LED interior lights, D3 ignition coils, new window tint, tip steering wheel with new S8 emblem, mk1 TT steering wheel air bag, mk1 TT 6 speed shift knob, new shift boot. |
