Hi just got this fault and I have checked the wiring around the compressor but didn't find any wires broke and the harness plug was cleaned but fault won't clear is it time for a new compressor or is there any way of checking for faults.
Thanks trevor Last edited by carmel120; 18th March 2023 at 11:36 AM. |
Found similar posts elsewhere and two stood out that you might already have seen. You've checked the wiring at the connector end and the connector itself, but I saw these the following comments that are worth investigating, both being broken wires:
I was able to fix my issue with N111, wire was pinched in the wheel well. 1st time I removed the sheild and the compressor as mine was broken way up where it goes into the main loom. Also worth doing a resistance check as mentioned in this post: https://forums.ross-tech.com/index.p...71/post-256551
Cheers Sean 🍻 |
