Old 22nd May 2023, 08:32 AM
If it's the same fault I had (or similar) you can remove and short-circuit the relay to start the car, it's quick and easy to test that.
I ran mine like that, with just a wire instead of the relay, for 2 and a half years until I could get it fixed as part of an MJ overhaul.
(Admittedly mostly during Covid times so it got very little use)
Old 22nd May 2023, 09:26 AM
Originally Posted by donp38 View Post
Hi.
Yep, I was kinda sure!....but now I am unclear if that was correct..
However, now completely dead.
I turn to crank, the battery light goes off on the dash but no click or any noise.
It's been a while since I had D2 but I am pretty sure that lights on the dash should stay on while you are cranking. If they go out the there is not enough power available which would suggest bad or flat battery or poor connection from battery.
Have you checked battery voltage at rest and while trying to crank and also voltage by the starter?
Old 22nd May 2023, 12:16 PM
donp38 donp38 is offline
You are right.
Working alone yesterday so not able to check at starter.
The battery is new (three mths old), and sits on a Ctech so have assumed it is fine. Will check that...goodness!..
Have we a part number for the F125 and suggested supplier?
I think I should get all bits and bobs and when I get another pair of hands at the weekend we can get to the solution...somehow..
I Also need to sort that jumper idea so that I can fault find better..
Many thanks...
Old 22nd May 2023, 03:00 PM
Part number for the F125 switch is 01L919821B, assuming yours is from '99 or newer. It's a 10-pin connector. Supplier wise, depends on what you want. For OEM, the following site has them listed at 328 Euro.
https://originalteilemarkt.de/multif...19821b-2807334
You can go further East (if you know what I mean) and get them a lot cheaper, which I did.
BTW Updating your signature line with details of the car will help in circumstances like this, where there are variations in parts depending on year.
Old 22nd May 2023, 07:12 PM
Spanker's Avatar
Spanker Spanker is offline
There's also this at a lower price for that part number:
https://www.ht-onlineshop.de/vag/ant...f_128007_29039
Dean
Old 22nd May 2023, 07:29 PM
when testing voltages measure the voltage at the box on the chassis leg and earth on the body. Then measure voltage on the chassis leg and the engine. Then check the resistance from the chassis to the engine. Could be a bad engine earthing lead.
Old 22nd May 2023, 08:59 PM
thanks all.
I am suspecting maybe a poor earth.
checked the battery and battery earth this evening...like new...
with extra pair of hands on sunday I can do better checks...
Am I correct that if I can see on vcds the gear selector changing and in P then it will not be the F125 switch?
Actually, it is just like the starter has jammed..
Old 22nd May 2023, 09:03 PM
NO, absolutely NOT!
There are multiple separate circuits in the F125, the Gearbox ECU uses a completely separate set of physical tracks/contacts to the starter relay.
The contacts relevant to the starter relay are NOT monitored in any way by VCDS, they're purely "old school" wiring.
The five arcs bottom/left are the ECU information tracks, the four at the top are for starter (9/10) and reversing lights (7/8).
(Numbers relate to the 10-pin plug, 6 is unused)
ID:	29564   Click image for larger version
Old 22nd May 2023, 09:51 PM
Brilliant. Another site to source parts from. Bookmarked for future reference.
Old 24th May 2023, 04:56 PM
Great.
So if I do the bypass and the vehicle starts, then it is the F125 switch.
correct?
Assuming I have done the other checks..
Many thanks again.
