Go Back   A8 Parts Forum > A8 D4 > D4 - Everything Else
D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out
Old 8th June 2023, 08:58 PM
monkeyboyuk monkeyboyuk is offline
Default Some new buyer niggles….
So as some of you may know I’m now a fairly happy owner of a d4 to replace my beloved, but written off, d3 (rip)
However, I’ve had a few issues, some of which are ongoing, but the dealers been great so far in trying to get things resolved.
1/ regularly drops into limp mode - this now seems to have been resolved with a new turbo (under 80k miles)
2/ air con pump, error flagged in vcds
3/ auto stop start, error in vcds and I’ve been experiencing regular issues when trying to use. Ie getting stranded at a busy junction, having to totally ‘reboot’ the car
4/ suspension - no errors but it feels every bump n ripple in roads you could imagine - nothing like as comfy or smooth as my d3
5/ phone antenna
6/ lighting to rear n/s door
The dealer doesn’t have their own mechs but use someone else who I’ve not been enthused by…. They’ve not managed to resolve any of these issues other than the turbo one, apparently they can’t find faults
Yet, every time I scan they appear so there’s something there to investigate….
Any how’s, thought I’d share with you, including one of the early scans pre turbo being resolved, to see if anyone had any knowledgeable input to share on any of the errors
I’ve agreed with the dealer to take it to my local Indy for investigations so will hopefully get to bottom of things
Tia for any input
2021 Q7 4M, 3.0tfsi MHEV Black Edition
1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting…. ** FOR SALE **
1990 2.3 20v 7a Coupe Quattro
**SOLD** 2014 D4, FL 3.0tdi, phantom black, sport exec lwb
Old 8th June 2023, 09:00 PM
Code:
 Wednesday,17,May,2023,18:56:03:61808
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64)
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WAUZZZ4H6EN011996   License Plate: CV14FXC
Mileage: 129579km-80516mi   Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 28 30 34 36 3B 42 44 46 47
          52 53 55 56 5F 62 6C 6D 6F 72 81 85 88 89 8F 90 AC
VIN: WAUZZZ4H6EN011996   Mileage: 129579km-80516miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
30-Special Function II -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-CTBA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4H0 997 401 E    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  X14 0002
   Revision: 58X14---    CVN: 14D79D530000000038D3FF82
   Coding: 0A2A4032052601030800
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM30TDI0114H0997401E 001002
   ROD: EV_ECM30TDI0114H0997401E.rod
   VCID: 2F6D7D8B76EC3CEB62-807A
   VINID: 9D196AAAA1181957800412491801BC4F75
1 Fault Found:
5171 - Boost Pressure Regulation
          P0299 00 [096] - Control Range Not Reached
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 129173 km
                    Date: 2023.05.16
                    Time: 14:19:28
                    Engine RPM: 1873.00 /min
                    Normed load value: 87.1 %
                    Vehicle speed: 137 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 23 °C
                    Ambient air pressure: 1020 mbar
                    Voltage terminal 30: 14.120 V
                    Unlearning counter according OBD: 37
                    Charge Pressure Actuator: activation: 90.38 %
                    Charge air pressure actuator: acknowledgment: 90.38 %
                    Ambient temperature: 17.0 °C
                    Charge air pressure: specified value: 2689 hPa
                    Accelerator pedal travel: 48.10 %
                    Air mass: actual value (mg/stroke): 1093.5 mg/stroke
                    Actual charge pressure: 2330 hPa
Readiness: 0 0 0 0 X
Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
   Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
   Component: 0BK 30TDIRdW  H16 1011
   Revision: --H16---    CVN: 975A626A
   Coding: 000001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMALX51011 002022
   ROD: EV_TCMALX51011_002_AU64.rod
   VCID: 7CF79AC7F71A177397-8028
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 T    HW: 4H0 907 379 T
   Component: ESP PREMIUM   H10 0665
   Revision: --------    Serial number: --------------
   Coding: 60E5EB8006A7D701E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 4385213BCA64A88B96-8016
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 EB    HW: 4H0 907 064 EB
   Component: BCM2 2.0      H36 0521
   Revision: 00002001
   Coding: 05B76F4E000000000000
   VCID: 6DD1A783B4608EFB10-8038
   Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
   Component: J764 ELV MLB  H40 0046
   Serial number: 0213000400877009
1 Fault Found:
02241 - Engine Control Module; Immobilizer Data not Adapted
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 39
                    Reset counter: 52
                    Mileage: 128904 km
                    Time Indication: 0
                    Date: 2023.05.16
                    Time: 09:11:54
Address 06: Seat Mem. Pass (J521)       Labels: None
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000086484489
   Coding: 0038320000047201000001010101112131313333283333
   VCID: 346772E797CA1F331F-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 N    HW: 4H0 820 043 N
   Component: Klima 4 Zonen H20 0201
   Coding: 362102B83C0000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2B55699B42F440CB4E-807E
2 Faults Found:
0129 - Motor for  Left Side Window Defrost Flap
          B10D7 22 [009] - Signal Amplitude Too High
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 16
                    Reset counter: 12
                    Mileage: 128904 km
                    Date: 2023.05.16
                    Time: 08:47:51
0378 - Coolant Circulation Pump
          B10D0 04 [009] - Internal System Fault
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 8
                    Mileage: 128904 km
                    Date: 2023.05.16
                    Time: 08:53:29
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 AB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0242
   Revision: 19020001    Serial number: 00000052629401
   Coding: 0105001440349FE0C9014087A0001800009DC30A2F0802018000089461001700004000240B0000
   VCID: 68DFD6979B82ABD363-803C
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 130911  H36 0090
   Serial number:         131021203832
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 22109416
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 06 01 2014  00001353
   Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA107206000005727074
   Coding: 020300
   Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
   Serial number: B0C884E6000000000001
Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H81 0084
   Revision: --------    Serial number: 003P10014JPZ Dataset Number: 4H0909602J  0013
   Coding: 30333045313430303038554A305234483053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
   ROD: EV_AirbaAU10BPAAU64X_VW51.rod
   VCID: 3B7559DBB294D04BDE-806E
   Crash sensor for side airbag: driver side:
   Serial number: 3575HRB40672ATKA31HC
   Front Passenger's Side Airbag Crash Sensor:
   Serial number: 3585HRB40692ATKA91OS
   Rear Side Airbag Crash Sensor (on driver's side):
   Serial number: 3515JRB400450QLQFHBS
   Passenger side rear thorax airbag crash sensor:
   Serial number: 3525JRB400450QLQ713/
   Crash sensor for front airbag: driver side:
   Serial number: 3554VRB401C50REKK0FW
   Crash sensor for front airbag: front passenger side:
   Serial number: 3564VRB401050R5M6GST
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Component: Lenks.Modul   H04 0005
   Revision: --------    Serial number: 01335NAA0004Q
   Coding: 000034
   VCID: 377D45EB86BCF42B3A-8062
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Component: E221 - MFL  H08 0010
   Serial number: 25 10 2013  C0368624
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4H0 920 910 M    HW: 4H0 920 910 M
   Component: TDieGB------- H53 0621
   Revision: 36081095    Serial number: 658121213592023
   Coding: 33A608001B412600010000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU64.rod
   VCID: 2E53608F71E635E369-807A
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
   Component: Analoguhr D4  H05 0225
   Serial number: 2131204000185
Address 19: CAN Gateway (J533)       Labels:| 4H0-907-468.clb
   Part No SW: 4H0 907 468 AE    HW: 4H0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001227316 Dataset Number: 4H0909515K  0080
   Coding: 80CD077D00
   GVL: FF83E858FEE3E0CF8000
   ASAM Dataset: EV_GatewPkoUDS 001019
   ROD: EV_GatewPkoUDS_001_AU57.rod
   VCID: 74E7B2E7DF4A5F33DF-8020
   Battery Monitoring Control Module:
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 50344G29011911505359
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Component: J532_DCDCStab  H05 0006
   Serial number: 13337003213021200410
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H16 0200
   Coding: 2800000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 387F46D783A2FB5333-806C
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000052712
   Coding: 01010101000000000001000202
   VCID: 64C7C2A767AACFB34F-8030
Address 34: Level Control (J197)       Labels:. 4G0-907-553.clb
   Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H19 0783
   Dataset Number: 4H0909553H  0037
   Coding: 008000
   ASAM Dataset: EV_AirSuspe 003025
   ROD: EV_AirSuspe_VW51.rod
1 Fault Found:
403200 - Function Shut-Off Active
          C10C8 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 48
                    Mileage: 128904 km
                    Date: 2023.05.16
                    Time: 09:12:25
Address 36: Seat Mem. Drvr (J136)       Labels: None
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000086484634
   Coding: 00383B0000057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA7701FJ99
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 377D45EB8EBCF42B3A-8062
Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H06 0273
   Revision: --------    Serial number: 0000086376857
   Coding: 011F1E015E0162C202083006
   VCID: 489F3617FB428BD343-801C
Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
   Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0005185981 Dataset Number: 4H0909852F  0020
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326B74FF65DE11030D-8066
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0323755591
   Coding: 011B0E2280B93985F320C7C40A0316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.030  H08 0006
   Serial number:     WOO25970311
   Coding: 901F00
   Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
   Component: Dachelektroni  H13 0080
   Serial number: A2014000000000766217
   Coding: 010000
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS013  H06 0005
   Serial number:     WOO10005VW0
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Component: GEB.F.Heckoef  H16 0811
   Serial number: 93101628
Address 47: Sound System (J525)       Labels: None
   Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
   Component: BOSE-G3-C7    H07 0160
   Revision: CJ007001    Serial number: 00000000064473
   Coding: 030000
   Shop #: WSC 31716 002 1048576
   VCID: 1D31B7430440BE7BC0-8048
Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0273
   Revision: --------    Serial number: 0000086931726
   VCID: 3C775AC7BF9AD773D7-8068
Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000926803 Dataset Number: 4H0909522D  0017
   ASAM Dataset: EV_ParkiBrake 001028
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C576A8747FA47F347-8078
Address 55: Headlight Range (J745)       Labels:| 4H4-907-357-V2.clb
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Revision: --------    Serial number: -------------- Dataset Number: 4H0909865C  0018
   Coding: 02F6022022130200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   VCID: 31697BF360D82A1B74-8064
   Left LED Headlamp Power Output Stage 1:
   Subsystem 1 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7530
   Coding: E00300
   Right LED Headlamp Power Output Stage 1:
   Subsystem 2 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7530
   Coding: E00300
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0021
   Coding: E00300
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0021
   Coding: E00300
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109A+0E7855924
   Coding: 010103010000000001
   VCID: 285F96975B026BD3A3-807C
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 4H0 035 670 P    HW: 4H0 035 670 P
   Component: H-BNT-EU      H47 0798
   Revision: --------    Serial number: 179A.0E7517135
   Coding: 02010100000BF1EF45908B1E00000003000001000000000000
   VCID: 31697BF368D82A1B74-8064
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDDC90128LP
   Subsystem 3 - Part No SW: 4H2 919 600 H    HW: 4H2 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000143040
   Subsystem 4 - Part No: 8R0 060 961 F
   Component: CD-Database  5571
1 Fault Found:
01524 - Antenna for Telephone
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 8
                    Mileage: 128904 km
                    Time Indication: 0
                    Date: 2023.05.16
                    Time: 08:48:04
             Freeze Frame:
                    Voltage: 11.80 V
Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0273
   Revision: --------    Serial number: 0000061939243
   Coding: 010F1E01400062C202083006
Address 6C: Back-up Cam. (J928)       Labels:* None
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0125931
   Coding: 020D000001000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0046
   Revision: 10012001    Serial number: 008400796 Dataset Number: 4H0909541F  0007
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FEDBD8BB66C7CEB22-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000135495 Dataset Number: 4F0000000__ U001
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63C5C1BB6AA4C88BB6-8036
1 Fault Found:
0046 - Rear Right Door Lighting Color 2
          B1131 01 [009] - Electrical Failure
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 8
                    Mileage: 128904 km
                    Date: 2023.05.16
                    Time: 08:47:55
                    Terminal 15 status: On
                    Voltage terminal 30: 12.0 V
                    Control Module temperature: 22 °C
                    Processor load: 36.0 %
                    Color setting Ambient: Cold white
                    Status terminal 58s: OFF
Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
   Component: TSG HR        H06 0276
   Revision: --------    Serial number: 0000086141064
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H08 0083
   Revision: 0R0D5015    Serial number: SN131109  0150
   ASAM Dataset: EV_GSM2x3Mono 001017
   ROD: EV_GSM2x3Mono_AU64.rod
Address 85: On Board Cam. (J852)       Labels:| 7P6-907-217.clb
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0081
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4H0909547F  0046
   Coding: E0140000
   ASAM Dataset: EV_OnBoardCamerDPC 001007
   ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00014157217402 Dataset Number: 4H0909880D  0019
   Coding: 672FF2
   ASAM Dataset: EV_IVBDriveSideFrnt 001003
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00014157205001 Dataset Number: 4H0909881D  0019
   Coding: 272FF2
   ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8F: Pretens. Frt Left (J854)       Labels: 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 C
   Component: RGS-VL        H13 0080
   Dataset Number: 4H0909614C  0003
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
Address 90: Pretens. Frt Right (J855)       Labels: 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 C
   Component: RGS-VR        H13 0080
   Dataset Number: 4H0909615C  0003
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
Address AC: Reductant Control (J880)       Labels: 4G0-907-355.clb
   Part No SW: 4H0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0011
   Revision: 00000000    Serial number: 132660318 Dataset Number: 4H0909571E  0015
   ASAM Dataset: EV_RDCMA00100 008040
   ROD: EV_RDCMA00100.rod
End-------------------------(Elapsed Time: 07:27)--------------------------
Old 10th June 2023, 11:37 AM
Address 05: 02241 - The ECM needs reflashed with same or newer software. It might explain the issue you had in point 3 of your post. For other VAG cars I've read about with the same issue, there's is more severe in that the car starts and then stalls again, and continues that way.
Address 08: 0129 - Seems to be an issue that others have encountered, which is some plastic lugs (end stops) breaking off. The following thread gives further details:
https://www.audiworld.com/forums/a8-...issue-3013380/
and the following video should help with removing it: https://www.youtube.com/watch?v=v_GcY17Zl-I
Address 08: 0378 - Check out the following thread, which also has links to a write-up: http://forum.a8parts.co.uk/showthread.php?t=14104
Address 34: 403200 - From what I've read, it seems that this only appears if you've been into the MMI to activate the 'tyre change' option, or if the car thinks it is being jacked up. Normally the date indicates when this last happened, but all your dates are the same. Had all the error codes previously been cleared, with this scan being after that?
Address 5F: 01524 - Can't find anything useful about this as most are old posts about people retrofitting BT to their vehicles. Only suggestion I have it to check the coding for Address 5F.
Address 6F: 0046 - Again, can't find anything useful. Try clearing code and see if goes away. If not, try changing colour to see if that works. If not, then it might be gone completely, as the text implies (Electrical Failure).
Old 10th June 2023, 12:20 PM
Thanks! Actually looks straight forward enough I think I might have a bash at that, although be prepared for some blue air, as anything I touches tends to end in tears…
Ref address8 that’s good to know too, I feared the worst in terms of a pricey fix.
This was my first vcds scan, however I’d had into an old school mate who has a vag Indy shop in my hometown which I happened to be visiting. He’d scanned and cleared everything on the Tuesday (16/5) then I drove home and scanned when I got home on the Wednesday (17/5). We’d had it up on the ramps to look at suspension but he couldn’t see anything other than what looked like some perishing to bushes, no excessive play etc.. we’d had in jack mode then.
I’m thinking the levelling module is faulty as it will raise and drop but Ive not notice it self level on occasions when stopped on a steep junction for example. This was always noticeable in my d3. Wondered if this fault in turn could also then be aff3cting general ride if it wasn’t knowing what do do ref levelling off etc
Old 10th June 2023, 04:12 PM
I didn't even know self-levelling was on the D3.
Adding to your point about stiff suspension, do you have Towing mode enabled, as I've seen suggestions that that can attribute to the harshness? Have seen multiple references to hard suspension both on the D3 and D4, but no concrete solution to it anywhere on it's cause/resolution.
Old 10th June 2023, 08:51 PM
Don’t think I sawing tow mode enabled but will double check. The suspension doesn’t seem hard, it’s super wallowy n feels a bit floaty at times, crashes about over holes bumps that I’d normally have had no issue with in the d3. Both d3 and d4 are sport models by the way
Old 25th July 2023, 04:29 PM
GlynH GlynH is offline
I have had the 08 HVAC issues that you see on your car.
steamship refers to the 0378 Coolant Circulation Pump and links to my thread about it.
I still have the 0129 Defrost Flap issue which manifests in a sharp crack shortly after the ignition is turned on and the flap is exercised and some smaller clicking sounds when the flap is adjusting.
The end stop on mine was broken as steamship also refers but I believe the vent/flap/motor assembly was something like £260 so I've lived with it as it does seem to work but the clicking and error code is annoying!
Seems like I've been chasing you around the forum today with what look to be some common faults affecting the D4...
-=Glyn=-
Old 25th July 2023, 08:07 PM
Haha, indeed, got my own stalker
The de mister wasn’t annoying me much until one evening I was out late, car was fogged up and the passenger side would not clear so really wasn’t helping with my view. So gonna be something I need to get sorted. I don’t get any noises or anything to suggest there’s an issue, just the codes coming up…
I’ve since had a new fault, the mem seat controls on driver side have stopped working…….
-=Glyn=-
