Originally Posted by donp38
If not fixed then.
Step 2 : VCDS sequence..
However....I assume VCDS will tell me what to do and when?
Many thanks..
I haven't used that option, but the following post gives instructions (which I believe VCDS prompts for):
https://forums.ross-tech.com/index.p...79/post-220317
However, as MJ mentioned in the post I linked to earlier, this is only required IF the ABS pump was completely drained or somehow got air in it, and this bleed process is done through the front callipers only.
You mention the squelch from the ABS pump. Just to confirm, are you hearing it from the ABS pump area or from the brake pedal area inside the car? Can you upload a video of it, as it might help others diagnose the issue.
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
Sold!
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
