Old 3rd October 2023, 10:23 AM
There is fluid loss from the ps cooler and the atf cooler. Brake hose clamp tools are handy to block off the ps hoses to reduce the amount which escapes.
Laser 7254 Hose Clamp
All the non-genuine rads I've seen come from the same Chinese tooling. The Mahle one just has an expensive sticker on it.
Ramps will be fine and won't affect refilling the ATF
Aha. I have clamps. Will ramp it and I will remove the front bumper - saw a chap on youtube do it.
I purchased a budget priced one, and the only fitting issue I experienced was the threaded stud used to hold the piece of plastic trim at the top of the radiator.
I did spot a genuine one on tradition but getting it here safely (as MJ mentioned a while back) would be a challenge?
'Budget' radiator it is then.
Thanks guys.
Paul
Gosport UK
________________________
Polestar 2 Long Range
Audi S8 2002 FE Avus Silver / Extended Red Leather. https://forum.a8parts.co.uk//showthread.php?t=16187
Honda Jazz
