Old 27th May 2023, 09:36 AM
sarg sarg is offline
Would offer to do it no problem, but a bit far from Londonderry to West Northamptonshire... and there's quite a bit of water in between... unless you meant at the meet!
Sean, no need to be here
But stand by for PMs
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 27th May 2023, 10:57 AM
By all means, please do if you get stuck.
Old 28th May 2023, 05:12 PM
The bugger is out at last
Note the corrosion of the clip, I think water was getting trapped between pipes corroding from outside
Next task, get the replacement in and put back together
ID:	29588   Click image for larger version
ID:	29589   Click image for larger version
Old 29th May 2023, 03:01 PM
It’s all over for the S8 coming to the meet
This is the replacement coolant pipe
Old 29th May 2023, 03:14 PM
I thin these were sandblasted or similar before powder coating, the blasting smoothed out a rotted through hole, then powder coat over
I’ll be washing one of the BMWs tomorrow ready for the trip
ID:	29592   Click image for larger version
ID:	29593   Click image for larger version
Old 29th August 2023, 11:04 AM
A little update:
The coolant pipe problem seems to be resolved at second attempt. Got a couple of secondhand pipes from the US sent directly to MJ, which she got balsted and powder coated, one of which is now installed and am not seeing any coolant loss.
However, not yet fuly bled the system as cannot get it upto temperature for long enough because:
1. While laid up, the fuel pump has borked
2. The alternator has given up, probably as a result of its coolant shower
So, alternator is next on the list, after which will try to get it down to MK for the fuel pump, but we're off on a little holiday so it will have to wait a while
Old 17th October 2023, 12:39 PM
cenick cenick is offline
Angry I think I may have the same problem
Came home last night and noticed what I thought to be oil, but quickly realised it to be antifreeze, car had been sat for a day in this position.
https://share.icloud.com/photos/065j...uqUKHGeSLigS0g
I have a feeling it may have been leaking for a while as my coolant was low in the tank.
Seems to be drivers side & more toward the front possibly however, that may be due to undertray confusing things.
No obvious signs of leakage and oil is clear so thinking it maybe the same pipe?
Are these available still and does anyone have a part number and apologies if this has been asked before!
1999 D2 4.2 Quattro sport
1999 D2 2.8
2001 A2
2003 A2
Old 17th October 2023, 12:42 PM
Definitely not available new, but you need to reach out to MikkiJane who may have a refurbed item available, but you need to check first, it's very easy to find with the bonnet open
EDIT: also check your washer fluid as that is right below the washer tank
Old 29th October 2023, 09:49 AM
Thanks, I checked washer fluid and that was okay. Anyway I’ve dropped it off to my mechanic for further investigation, which is 20 miles away and it didn’t loose too much coolant to be fair, I could still see plenty in the expansion tank.
Fingers crossed 🤞
1999 D2 2.8
2001 A2
2003 A2
Old 18th April 2024, 12:35 PM
After much time, the coolant bathed alternator has now been replaced and she is running again this morning.
Weekend will finish bleeding the coolant, then it's putting all the plastic trims back on and off for an MOT, with fingers crossed the fuel pump is not goosed
