Is there a link to the correct procedure somewhere?
They are probably either trying to vacuum bleed it which simply won't work, or bleeding it with the pedal which is very high risk on a 20 year old car as any moisture or corrosion in the far travel of the master cylinder (inevitable in D2s which seem to mostly have brake fluid like seawater) will trash the seals when you press the pedal to the floor.
The solution is to pressure bleed it with 2 bar of pressure required to get through the ABS unit. You have to have a proper tool for this. Good luck to anyone trying to pull 2 bar of vacuum ![]() Just changing the calipers doesn't need the ESP pump bleeding, but if they have let it run dry it'll need basic settings running on the pump to cycle the fluid through. |
There is a pdf with instructions here:
https://****************/viewtopic.php?t=17 MJ is right, doing it with a proper tool makes all the difference, the last time I had it done 2l of brake fluid was enough to flush through and bleed everything. The tool looks like this: https://www.ebay.co.uk/itm/223639876...Bk9SR4LxirSJYw |
Thanks guys. They’ve managed to get it bled - apparently there was a lot of air in the system, which I don’t really understand as they’d used hose clamps at the wheels. Going to pick it up shortly.
Just in case, are the master cylinders still available? I think I might get one to put on the shelf
They've already sorted it, but for future reference, it starts on page 161 of the following PDF:
Service Manual Brake System.pdf Since you'll only be doing routine 2 year changes, use a pressure bleeder as MJ suggests, as it's a doddle and you don't have to worry about the ABS unit (just make sure there's enough fluid in the pressure bleeder). Part number for the brake master cylinder is 4D0611021B. Audi Tradition don't have any, but Dean might be able to source an OEM one. As they say, other brands are available, but MJ can probably recommend particular ones to use.
