Old 4th March 2024, 04:42 PM
Forgot to say, if doing the passenger side one, you do need to cut the old cable as it feeds down between the block and the metal timing belt cover, and you can barely get your little finger into the gap, but you can run the new one over the top... unless you just happen to be doing the timing belts at the same time, and you can run it properly.
