D2 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
Hi all
After replacing my knock sensor I was in the process of replacing the inlet manifold when I noticed something in cylinder 6 runner (see pictures). I have been chasing a slight miss fire / rough idle for a little while now and maybe this is it. I can't get the piece out and have checked the cylinder with an endoscope and can see no damage to the piston, cylinder walls or valves. It looks like I may have dodged a bullet there. What are my options? It's clearly a piece of the variable inlet runner and even though the manifold looks like it should split I doubt very much it's going to want to. Even if I could split it would I be able to get parts? Is this the correct part number? 077133185AS. Honestly guys, I'm getting really fed up with this car. I try to do everything I can to maintain her correctly using only genuine parts where I can and yet she just keeps constantly kicking me in the nuts. Whatever happens her is going to be expensive, I can just feel it. Thanks Frank
Audi S8 D2 2002 88k mls Ebony pearl effect black. Grey interior. |
Will this do?
eBay https://www.ebay.co.uk › itm 2004-2006 VW PHAETON 4.2L - Intake Manifold 077133185AT
After researching it looks like one of the aluminium brackets has broken. No piston damage would indicate a clean break.
Also, if I want to go brand new it looks like 077-133-185-CA is the replacement. Can anyone confirm this for me please.
Go buy a lottery ticket.
Tell me about it. When I had mine apart last year, I decided to replace most of the sensors and windscreen washer motor, as it seemed like a good idea. Less than a year later, and the motor has failed and so has the oil sensor. Bumper off plus other bits job, and the weathers lousy! For the AQH, AVP, BCS and AYS engine codes, 077133185CA is the most recent version (2015). If you can find old 'new' parts, others to consider end in AT, BJ, BM or BT, as they are all the predecessors.
Thanks very much for the reply and the information. It looks like 2k for a new unit. That's a bitter pill for a car that's worth maybe 6k.
There are a few available of various prefix's for around the £400 mark. I might consider a little project and buy one to see if I can make a good one from the two. I'll keep looking for a while, see if anything pops up. In all honesty I don't like fitting used or bodged parts, it usually comes back to bite me in the end.
Hi all again and apologies as I seem to be replying to my own thread here quite a lot. I just need some more info so I can plan my route forward.
Is this a common problem and does anyone know of any examples where it has ended in cylinder or piston damage? I ask because going down the repair or use of second hand parts route may simply mean I am setting myself up for failure again. Maybe I won't be so lucky next time. If it is a common problem then brand new or removal of the flaps altogether seems to be the only sensible solutions. What will be the consequences of removing the flaps. Will I even notice the difference?
As you may have seen in another thread, I’ve just clocked up 200K miles and not had this problem. Fingers crossed!
https://forum.a8parts.co.uk/showthread.php?t=12128
Well I managed to pull out the broken part by simply removing the throttle body. It looks like a clean break so I am confident there are no other bits floating around.
Still not sure of my route forward yet. It's not a big job removing and replacing the intake Manifold so I'm considering fitting it back as is to see how she runs. If I could get a new one for around £1500 I'd buy it but I just can't bring myself to spend £2500 which is what Audi quoted me, with a 10% discount. Who knew these cars would be so expensive to maintain eh? Mmmmm.... Actually as I think about it, I think we all know that.
Dean Future work on "Red Dwarf": Fridge, solar sunroof, radio-controlled clock, interior and exterior dimming mirrors, Alcantara headlining/pillars/rear shelf, rear US outer lights, passenger memory seat, rear electric (lumbar and headrest) heated seats, Servotronic. __________________ Current: 2002 A8 D2 S8 FE - "Red Dwarf" - Misano Red - Platinum/Silver Interior, PDC, Sat Nav Plus with BOSE and hidden Dension Bluetooth, Multi-changer, Heated Front Seats, Bi-Xenons, FE Wheels, Phone Prep with Nokia 6210, Detachable Towbar, Rear Blinds, S8 plate but no other optional extras 1st Place Winner - A8Parts Annual UK Meet 2018 1st Place Winner - A8-Freunde Annual German Meet 2018 2nd Place Winner - A8-Freunde Annual German Meet 2019 2002 A8L D2 with a factory fitted S8 engine and drivetrain - "Evergreen" - Irish Green Pearl (TBC) - magnolia leather seats with magnolia door cards/door trims, magnolia leather head-lining, extended leather pack 3 (dark green leather dash, upper door cards, steering wheel, lower dash, centre tunnel and rear parcel shelf), factory black external trim (in lieu of chrome), self-levelling suspension, Servotronic, Brembo brakes, "gullideckel" / "man-hole cover" / "pie-plate" 8Jx18 polished 10-hole design wheels typically seen on the W12, Park Distance Control, heated windscreen, multifunction steering wheel, Vavona burl (burr-walnut) wood inserts with cream/magnolia door switch trims, phone preparation to the front with Nokia 6091 phone, phone preparation to the rear with Nokia 6091 phone on the central rear console, third phone preparation in the rear centre console, rear blinds, rear headrest release feature, rear electric heated seats with lumbar and recline function (the rear passenger seat has the facility to move the front passenger seat forward), BOSE audio, Rear Screen Entertainment (RSE) with dual factory fitted Alpine screens, integrated DVD player (under the centre of the rear bench with 4 DVD storage slots) and two remote controls (the controls and inputs for the RSE are in the rear centre console and the screens can operate independently of each other,) factory supplied leather headrest covers to hide the rear screens, rear vanity mirrors (standard A8L), dark green rear wedge footrests with cream piping, front passenger memory seat, dark green floor carpeting and mats – piped in cream, rear slumber pillows for the headrests, integrated fridge with integrated tumblers inside the rear centre headrest bar compartment, solar roof, auto-dimming interior and exterior mirrors, factory driver’s seat fire extinguisher, tire pressure monitoring system, first aid kit, 12 V socket in the boot, TRACKER, derestricted – top speed is 155mph plus 2007 A6 Allroad C6 3.0TDI Quattro - Highland Green (Audi Exclusive Colour) - Cream leather interior with Wood, Advanced MMI, Keyless, Bose, Advanced PDC, Sunroof, Heated Memory Seats, Adaptive Xenons, Adaptive Air Suspension, Servotronic Previous (went to good homes): 2002 A8 D2 2.8 Quattro Sport - "Big Red" - Tornado Red (Special Order) - Twist Interior, PDC, Passenger Memory Seats, Symphony II with BOSE, Heated Front Seats, Bi-Xenons, Auto-dimming Mirrors, 20" FE Wheels, Servotronic Steering 2002 A8 D2 2.8 Quattro Sport - Aqua Blue Pearl - Twist Interior, PDC, Sat Nav Plus with BOSE, Multi-changer, Heated Front Seats, Bi-Xenons, Auto-dimming Mirrors, Avus Wheels |
