23rd May 2024, 10:06 AM
Originally Posted by steamship
4E099381FN is the correct part number for the right one, with 4E099381FL being the left side. There isn't any superseded part numbers for either unfortunately.
The only 'upgrade' I've read about is more of a way of not throwing an error code, which is a resistor bypass, as mentioned in the following post:
https://forum.a8parts.co.uk/showpost...43&postcount=7
It won't however help if the engine mount has completely failed.
Thanks, ok so I’m looking for the OEM mounts only then. I’ll get in to that... do you know anyone that you can recommend to do this job or has an engine support frame that I can hire or loan? Cheers,
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
