Old 23rd May 2024, 01:29 PM
dsasa dsasa is offline
Default A8 3,3 tdi d2 2002
Please anyone could help in following:
When connected VCDS then can not access Immobilizer , message that no response from controller?
Also can not perform login for shanging of Instrument Cluster ( cahnnel 50 )
Also some other functions in VCDS are not available.
So I am not sure if it needs to load new map and as well which instrument is needed for loading new map as I do have original map downloaded from Audi!!
Any help much appreciated
Regards guys
Old 23rd May 2024, 03:15 PM
I've more questions for you than answers.
1. Are you using a registered version of VCDS or a cloned version?
2. Why are you trying to access the Immobilizer module?
3. Why are you trying to access the Instrument cluster, which on the D2 is Address 17?
4. What other functions in VCDS are not available?
5. What type of 'map' are you referring to? Navigation - It's a CD in the RNS-D / Software module map - didn't think Audi would offer the facility of downloading maps from them.
6. Can you give us some history as to why you're doing this now?
7. Have you had the car for a while and it has just started having problems?
8. Have you just purchased the car and was it driving okay or did it have problems?
9. What if any symptoms are you experiencing with the car that's making you ask the above questions?
10. Are you able to do a full scan of the car with VCDS? Can you post it here? If there are errors, have you tried clearing all the errors, driving the car and then scanning it again to see what ones reappear again?
Old 23rd May 2024, 07:51 PM
It is surely cloned version because it is chinese!!!
Try to see key code!!
I have another one where all displays are working correct while in old one in use digital displays are some when heated then scrambled and main display when cold can not see anything.
I will make all scan with VCDS and send log
Map for ECU
This car has been standing without moving for 6 years and I got is return instead of some money which former owner has been in debt to me.
Car is driving ok but as new in audi I want know as more as possible about it.
will post full scan tommorow
All errors I can clean in VCDS , no problem
Old 23rd May 2024, 08:03 PM
You have no response from immobilizer because on 2002 there is no separate immobilizer like on pre 1998 cars, it's integrated in instrument cluster. You cannot get code with VCDS, there may be some other aftermarket tools that can do it but I do not know any that will definitely do it. The best option is to desolder EEPROM chip and swap over to new cluster.
Old 23rd May 2024, 10:26 PM
sarg sarg is offline
Originally Posted by dsasa View Post
[color="Red"]It is surely cloned version because it is chinese!!!
There's your problem
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 24th May 2024, 07:25 AM
Following up on the responses to 3,5 and 8:
3. I've had both issues with the displays in the instrument cluster. My first one had the pixellation problem, and its replacement suffers from heat fading it out. You also can't just put in another cluster. It's needs to be coded, and for that you need to know someone with access to ODIS with a Gecko licence.
5 & 8. You say you're new to Audi, the car has been sitting for 6 years, but is driving OK, and you want to remap it!
Would it not make more sense to get to know more about the car, iron out any issues with it, and then re-map it? I'm assuming that's your intention, as I don't see any other reason for downloading an ECU map - again, highly unlikely downloading anything direct from Audi.
