Old 27th October 2024, 05:11 PM
You could try sending 'carmel120' a message asking him how he dealt with his issue, which was the same problem with the suspension raising and lowering repeatedly, although he hasn't been active on the site since November 2023.
Old 2nd November 2024, 11:04 AM
Toblahoe Toblahoe is offline
Thanks, Sent him a PM so i'll see,
In the meantime I checked his posts and found one that details a recalibration via VCDS, the measurements we're a bit off on my car, so I went through the whole process.
Same thing, car just lifts and lowers the rear over and over again until the compressor overheats.
Update:
So I have checked and tested each sensor today, all connections are clean, and wires are unbroken, I even tested the movement of each sensor manually whilst watching VCDS and they all seem to report correct readings. I even checked the valve block and other areas for leaks.
I have noticed that the car will sit stable whilst idling and no one is in the car. As soon as I sit down in the car, it starts this cycle of raising and lowering. Any new ideas?
Toby
2007 S8 D3 5.2 V10 - Jap Import in Daytona Grey
2004 BMW X3 2.5i Manual (Old Workhorse)
Previous:
2009 S5 4.2 V8 - Phantom Black with Red leather interior
2006 A4 3.0tdi Manual - Black with Black Leather
2001 BMW 323ci 2.5i Manual
