Old 14th November 2024, 10:38 PM
Default Battery goes flat.
My FL S8 seems unable to keep a charge for more than a week or two.
I've popped a few new batteries in over the last few years- but if I leave it for more than a week or two, the damn thing wont start.
Are there any obvious places to start looking for the problem?
Mine is an early FL S8, reg'd in 1999. Volcano black, black leather and black wood.
Old 15th November 2024, 08:35 AM
Two possible culprits worth investigating:
1. The battery connection block underneath the drivers side chassis leg. It should have a black cover on it. Remove it and check for corrosion. There are photos of it on the forum, but here's an illustration on what you're looking for (item #10).
2. The voltage regulator on the alternator may be failing/failed.
Name:	Screenshot 2024-11-15 093202.png
Old 17th November 2024, 12:57 PM
Me too! - an (minor...) ongoing issue for years: wouldn't be a noticeable problem with Herman if he was driven more than once or twice a month
Old 18th November 2024, 03:44 PM
Ah.
I see I double posted.
Thanks again.
I guess I can check the voltage regulator by checking the batt voltage while it's running.
S
Old 19th November 2024, 09:15 AM
Ah.
No problem. I thought I was having deja vu.
I read somewhere that a failing/failed voltage regulator actually causes a drain on the battery, but can't remember where I saw it posted. I'm also sure that one of the forum regulars replaced theirs not that long ago, maybe in the last year or so.
Old 19th November 2024, 11:49 AM
sarg sarg is offline
I replaced my alternator earlier this year, but that was a result of a coolant bath, nothing else
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 27th November 2024, 12:43 PM
Did you manage to progress this at all?
Audi S8 D2 2002 88k mls
