Old 5th March 2025, 09:14 AM
I think I might have a couple lying around if it really is the just switch!
The reason I say that is that I've replaced the boot latch more than once and it's never actually been the microswitch that's the problem, rather a part of the mechanism that triggers it. But being the squirrel I am I kept the working components, they're very easy to unclip from the latch.
My honest advice, given the relatively low cost, is to buy a complete latch from our sponsors so you have it on hand before taking things apart. The last thing you want is to get in there, find something broken/adrift and the latch cease to work at all!
And if you do repair or replace the latch test it with the boot wide open - i.e. simulate closing by pushing a metal bar (e.g. screwdriver shaft) into the space where the latch clasp onto the striker plate.
Removing the boot lid liner is relatively easy but there's a fair few fixings.
First remove the warning triangle and its support bracket then the bolts you can see inside the grab handle.
Then work round the edge and remove ALL the "furry head" screws and finally pull firmly, there are a couple of press-stud type connectors in the middle.
See also this thread from 2018, same problem (plus some others mixed in) and it was indeed plastic bits, not the switch! https://forum.a8parts.co.uk/showthre...ighlight=latch I gave very similar advice in post #8!
As I said there:
if it's failing there's a good chance that when you remove it the damaged parts may just fall out making it inoperable
Old 5th March 2025, 12:09 PM
BespokeDia BespokeDia is offline
Thanks all for your responses, very helpful. I'm not sure which part is actually gone so I'll do some further investigating. I spoke to the parts people and they have no complete latches in, only the wire from the bootlid to the latch which she said commonly goes!?! I'll up date my profile and add some pics as soon as she's clean and its sunny.
Old 13th March 2025, 12:22 AM
Mrfaz's Avatar
Mrfaz Mrfaz is offline
Hi mate i had same issue with mine and I opened it up just to have a nosey. When I had it open I tested the switch and it was fine it just needed the metal bar on it to be re adjusted. The bar had straightened up. I got some long nose pliers and put the back to it's original shape and it's been fine 6 months later.
Old 21st March 2025, 11:00 AM
So I dithered and didnt get around to fixing or repalcing the latch and now the boot won't open at all! I've tried with the key and the internal switches and no joy. The central locking is working fine and it makes a promising noise at the boot but theres nothing when you press the latch. The boots relatively empty and I've tried pushing and pulling and no change. It's like something has disengaged. I did a search and on an archived thread on this forum someone had a similar issue and resolved it by smashing out the tail lights to release the boot! Is this still the case or is there another solution that someone knows?
Thanks in advance.
Should I start a new thread for this?
2002 S8 in Blue with Light Grey Interior with Ski hatch. Xenon Plus headlights, 18in Avus Alloys.
Old 21st March 2025, 11:13 AM
You've got a ski hatch, that might help, not sure how though....
If you can get something through the hatch to remove the offside lights cover in the boot lid that definitely exposes some of the mechanism.
Though that's behind the keylock/button so may or may not be the end that's broken/disconnected?
Another thought is that sometimes a latch mechanism is stuck under tension but will release if pressure is removed. In this case pressing down firmly on the boot lid while unlocking.
A bit like wiggling the steering column to allow the ignition key to turn.
Old 21st March 2025, 06:47 PM
A bit drastic, so here is another option to consider. Another forum member had the same issue whilst on holiday, and found a solution on a Russian forum:
https://forum.a8parts.co.uk/showpost...1&postcount=19
Old 21st March 2025, 09:47 PM
Sean, I think that "bronze" coloured rod is the same one you can expose behind the light cover, if you can get at it through the ski hatch.
That said, cutting that hole is probably easier and not really that drastic. I was thinking of doing it as advance preparation given several issues with that catch.
Old 22nd March 2025, 08:31 AM
Totally agree, as you can see it in the second to last photo in that post I linked to. It definitely looks like an 'easier' option of opening the boot, as you'd be leveraging only a few inches, as opposed to a few feet if doing it through the ski hatch.
I've also thought of pre-cutting it, as although I've got a ski hatch, there's a rather large LPG tank in the way! Might be a job for the summer months.
Old 22nd March 2025, 10:24 AM
Thanks so much chaps. I’ll let you know what I do and how I get on.
Old 22nd March 2025, 10:34 AM
