Go Back   A8 Parts Forum > A8 D4 > D4 - Everything Else
D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out
Old 19th May 2025, 07:15 PM
Saff Saff is offline
Default D4 aircon leak
Hi folks,
I'm looking for a knowledgeable sort who can tell me the location of the aircon expansion valve.
The system will hold a vacuum and 10 bar of pressure on test (no engine running), recharge with refrigerant and work but will leak away in use over a few days. This suggests to me that it could be either (or both) the expansion valve or the compressor as they are the only moving parts. I'm kind of hoping it will be the compressor because it's accessible on the 4.2 tdi but the expansion valve may not be.
Any pointers to its location will be appreciated.
2010 D4 SE Executive 4.2 TDI
Old 20th May 2025, 07:36 AM
Check out the following PDF from the D4 Tech Dump thread. Start at page 210 (section 2.9) for full instructions on location and removal:
26-Service Manual Heating air conditioning.pdf
Old 20th May 2025, 09:40 AM
Thanks Sean!
It does look like a fiddle and I'm still hoping it is the compressor at fault for ease of access.
I'll study the job and see where it leads.
Thanks again.
