Originally Posted by Horrgakx
(Oh, and I've corrected the location of the sensor, which is bank 1 sensor 1.)
Your other thread specifically mentions it as being Bank 3, Sensor 1, which you got from the VCDS scan:
24416 - Linear Oxygen (Lambda) Sensor B3 S1; Pump Current Wire
I think you are starting to confuse yourself about which is which, and another reason I suggested that before replacing the 'faulty' sensor, you simply unplug it, drive it, and scan it again, which should show a different error code for the same sensor. If you disconnect the wrong one, you'll then have two error codes.
Looking at the picture of the exhausts I posted in the other thread, B3S1 should be the first sensor on the right side of the engine as you look at it.
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
Sold!
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
