Old 28th October 2012, 10:32 AM
Richierich37 Richierich37 is offline
Default Water ingress to cab :-(!!!!!
Hey guys, just back from a drive and noticed the windows were steamed up after collecting my sons comic from the shop, alarm bells started! First place to check was passenger footwell.........yup, soaked!!!!
Any ideas what's causing this to leak? It's going into garage next week for work so a wee pointer would be great!
TIA.......
Old 28th October 2012, 10:37 AM
47p2's Avatar
47p2 47p2 is offline
Blocked drains at the bulkhead
Nite Blue 3.0L SE Quattro
Old 28th October 2012, 10:41 AM
lots of answers for you to look at -
http://forum.a8parts.co.uk/showthread.php?t=3898
http://forum.a8parts.co.uk/showthread.php?t=3281
http://forum.a8parts.co.uk/showthread.php?t=30
http://www.audipages.com/Tech_Articl...tordrains.html
http://www.tyresmoke.net/forum/audi-...et-carpet.html
http://forum.a8parts.co.uk/showthread.php?t=3192
Happy reading!!
Old 28th October 2012, 10:54 AM
Holy moly I thought I was doing well finding this................
Old 28th October 2012, 10:59 AM
Old 28th October 2012, 11:07 AM
The first thing to do is decide (not easy) which of the 3 or 4 main suspects is the actual source.
If it's ONLY the passenger side could be Botangs hole.
If you hear "sloshing" going round sharp corners it's probably the aircon evaporator/condenser drains (orange drains)
Take the main front carpets up both sides and look underneath; they can absorb an ENORMOUS amount of water.
As noted by me in one of those threads, if it's the orange drains it's just as easy to take them right out and clean thoroughly rather than blow air through them which doesn't remove all the "crud".
Old 28th October 2012, 11:11 AM
Asd noted by me in one of those threads, if it's the orange drains it's just as easy to take them right out and clean thoroughly rather than blow air through them which doesn't remove all the "crud".
I hear ya fella, problem is I can't get anywhere near the car just now as its hammering down here and I've no garage to stay dry!
Old 28th October 2012, 11:31 AM
Right got it started, removed the side trim at the passenger tunnel side and located the big orange bit! Removed that and no water came Does this mean its not leaking from here????
Old 28th October 2012, 11:36 AM
Difficult to tell.
Take the orange drain out of the car and see if a trickle of water into the open pipe comes out of the "valve" end.
Either way clean out the valve with warm soapy water and check it works OK. Then soften it in VERY HOT water before easing it back into place.
Unless it's 100% OK before cleaning I'd do the other side too.
Old 28th October 2012, 12:14 PM
I would also suggest you do the drains either side of the transmission tunnel, they are the ones you need to attack with the air hose, or if you can get it on a ramp I think you can access them from underneath
good luck
