I put mine on the bottom of the rear view mirror/sensor housing/bracket with hot melt glue (as this suited the camera).
The wire tucked between bracket cover and headlining and was a tight fit. The 12v is ignition controlled and was soldered directly onto the PCB in there as it was hard to find 12v up there. |
Can you get picture of it for me please?
I can't picture how you done it in my head.
ScottB5
Did you get anywhere with this? I'm intrigued!
Current: 2007 Audi A8 3.0 TDI SE Quattro - ![]() |
Not yet.
I'm still unsure on the best location to fit it. I don't like having things in my field of view on the screen so it has to go behind the mirror but that's where the sensors are and they take up the space they I used on the previous car. When I get some time I'll sit down and do some test fittings.
Scott
This is the dashcam I bought from Amazon: E-Prance New Mini 0801 Original Ambarella A2S60 It's small enough to fit behind the mirror, although I did notice you mentioned you have sensors there. Assuming the fuses are in the same location (drivers footwell) on the D3, I ran the cable along the headlining, down the A pillar and around the dash. I then used the following two items to connect it to the cigarette lighter fuse. 12v Female Car Cigarette Lighter Socket Piggyback Fuse The excess cabling and Socket were then tied up underneath well above the bonnet release catch. I was a bit concerned before ordering that the socket fit might be loose, but it's a really snug fit, and there's no chance of the plug falling out. Apart from the chime when it starts and stops (with the ignition), you don't notice it at all. The only visible sign is if driving at night, when the small blue flashing LED reflects off the back of the mirror, but a small bit of tape would cure that. This is what it looks like from outside:
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! ![]() My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds Last edited by steamship; 29th May 2014 at 06:26 PM. Reason: Added Photo |
Sorry, will get a pic tonight. Forgot about the thread!
