I unwrapped it carefully from its bubble wrap packaging (untouched since delivery a while back). And it was bodged in exactly the same way with a bit of duct tape! ![]() ![]() Here are the two handbrake trims together. Is this a standard "solution" to a common problem?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 10th May 2014 at 02:53 PM. |
I took off the handgrip and plastic casing and could then see better down into the space. The switch was actually broken so the plugs were connected. Unfortunately the break is right through and close to where the wiring plugs fit on, so they are now waving around connected to a broken component with exposed conductors which could potentially short out on nearby metal components. Probably not a major issue as it would at worst turn the warning light on - or would that have other effects if detected by an ECU? The wiring doesn't seem to have much slack on it but I'll try fishing it out to remove the exposed broken bits of the switch. One thing is certain, replacing it is a major job. ![]()
No idea how this fixes to the main part of the switch though. ![]()
You seem to be having fun with this issue and all the posting. Just thought I would respond to assure you that someone is reading the posts!
I also have a bodged lever trim. I keep meaning to look at a proper solution as it does seem a common failing.
The solution Sergey suggested is to get some decent double sided 3M tape and basically stick the 'wood' trim to the top of the handbrake cover. Build it up in layers of tape until it's level with the surrounding trim when the handbrake is off. Job done and doesn't need touching again. I have a brand new trim sitting on a shelf upstairs (75 quid if memory serves!) but it's not a great colour match to the rest of the matching colour code wood so I didn't fit it. I imagine John's guide to accessing the switch is the only option for getting to the faulty handbrake sensor but wouldn't think it's too tricky?
my handbrake trim has been in the glove compartment since shortly after I bought the car, does seem a crap design, but with the armrests down you don't even know its not there. I can confirm Adrian's price as I thought about getting one from Audi as all second hand ones seen to suffer from the same problem, but at £75......naw!!
Audi S8 2015, Daytona Grey |
I "think" the duct tape bodge is to stop the tiny bit of plastic vibrating against the pinch bolt. Either that or there should be a rubber pad there which has gone AWOL.
I'm going to glue a small bit of rubber in place of the tape to do that, but as you say it's a rubbish design. I've glued a suitable rubber pad into the plastic stop under the front of the handbrake lever already and it works well. As for the broken switch I'm going to try and undo the screw and fish it out through the gap beside the handbrake handle, it looks just about plausible to do that with only the trims on the actual handle removed. With the handbrake pulled on it should all come out forwards underneath the lever as there are now no cables to constrain it. If I can then repair (or replace) the switch it ought to be possible to connect it to the wiring with a couple of short lengths of cable (with suitable blade connectors on) and then wiggle it back into place and screw it down again. If anyone wants a handbrake trim in Vavona (I think that's what it is, fairly orange-ish) I have one available at a fair price, though it does have a tiny crack across the top lacquer. (I've also got all the rest of a full set of Vavona trims apart from the door switch panels - these are just the beige plastic ones I swapped out)
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 10th May 2014 at 10:53 PM. |
Also, I absolutely hate it when you see a forum thread (not here though, or very rarely) where after a selection of constructive answers there is no further response from the questioner. Or worse just a "thanks, all OK now" with no indication of how they actually solved the problem. ![]() If I offer some advice I like to know (constructively) whether it was helpful or another option was actually better, and why. ![]()
I've attached some pics of the brand new handbrake trim I've got here so you can compare and see if there's bits missing or not
Thanks Adrian, nothing missing, just extra duct tape "padding" inside the "cup" of that strange downwards protruberance at the front end that gets gripped using the pinch bolt.
As noted, I'm going to "improve" mine by adding a thin piece of rubber instead. ![]() Edit: Done. While I was at it I noticed that the front 2" or so of the lacquered top had been badly scratched by the underside of the drivers armrest. Brasso, then Silvo and finally furniture polish and it's as good as new. OCD strikes again. ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 11th May 2014 at 01:18 PM. |
