Old 19th November 2014, 04:23 PM
Default Central locking
For the central locking and factory alarm I will be using wires from the door lock switch that activates central locking and alarm when locking/unlocking car with the key physically in the door lock.
I have removed wires 3 and 6 from the plug H3 as locking system is normally open so normally closed wires are not needed. Wires H3/2 and H3/5 are connected together and will go to common wire from the door lock switch in the door wiring harness where it enters the car. Lock / unlock wires will be connected the same place accordingly. This will ensure when aftermarket alarm is activated it will send signal to lock doors and wires connected to door lock switch will activate central locking and alarm the same way as if you locked car by the key physically in the lock.
To prevent factory alarm from going off at remote start it needs to be deactivated, for this purpose I will use wire H1/14 from alarm and it needs to be connected somewhere under drivers kick panel to brown/green wire that I need to find. I think it might be going to alarm de-activation button on B-pillar.
