Old 1st January 2015, 10:59 AM
Could it possibly be the engine block breather valve giving up the ghost?
I think you're onto something there! perhaps the rubber diaphragm has failed and is vibrating as it lets air out?
Its the black plastic UFO type object at the back of the engine.
Here it is in a picture I borrowed from another forum member's post as it shows the engine bay without covers.
It is easy to remove by jubilee clip or the Audi type clip, but I'm not sure if its safe to run the engine without it or with the rubber hose plugged to test if the noise stops?
Probably ok for a minute or two, as its just a sprung rubber diaphragm to let some crankcase pressure out when it builds up enough to be able to open the diaphragm.
This is how it looks inside:
http://forums.quattroworld.com/a8/threads/8649.phtml
Old 1st January 2015, 11:11 AM
Having had mine off it's held by Clic-R collars/clamps which are best removed/replaced with specialist pliers.
Old 1st January 2015, 12:45 PM
mark_le_b mark_le_b is offline
Thank you, I have the plastic covers off the engine, so have seen this
Will run car to see if this is the culprit
Appreciate the ideas
Old 11th January 2015, 03:44 PM
Eureka! This is the problem, found this was the noise this afternoon
Can anybody help with a part number so I can order a new one
I assume its easy enough to change over
Thanks
Old 11th January 2015, 04:25 PM
Thanks
The part number is 077103245B. As for fitting, it is held in place by two clips. I had mine replaced a little while back and just used bog standard Jubilee clips instead of the OEM type used by Audi.
Old 11th January 2015, 04:33 PM
Great - thank you
Old 12th January 2015, 03:23 PM
Thanks
Excellent! That's a easy fix.
If you end up needing a new one I think it is part no. 077103245B
for a 2001 S8. I think I paid the dealer around £100.
Its probably making a noise because the orange rubber diaphragm has split or fallen apart, but worth checking anyway just in case it just needs some cleaning.
Old 12th January 2015, 04:12 PM
I think Mark has already ordered one, but I got one from the USA for the princely sum of £27 including shipping!
Old 13th January 2015, 05:30 AM
I have ordered one - but because I was in a bit of a hurry I went with the dealer - cost £67 but it will be here Thursday,so I an fit at the week-end
Old 13th January 2015, 06:49 AM
Ah, should have read more carefully.
Was the USA one an Audi original part, or if not, is it working fine?
I'll be needing another one for the current S8, no harm in saving some money
