Old 5th October 2015, 12:59 PM
Scottnybottny Scottnybottny is offline
It's a strange setup as it definitely has lowering links installed, but I can only guess that they are set to original length. I have come to this conclusion as I looked into the suspension through VCDS and when running the output test it showed a figure of -20mm on the front. The car is not too low at all.
It is clear that a previous owner has been playing with it as all of the vcds tweaks are already enabled.
Does anybody have the original length link measurements to hand so that I can check?
Old 5th October 2015, 07:28 PM
CR51GYR-A8 CR51GYR-A8 is offline
Can't you just adjust them to your desired length?
And leave them fitted.
They're very easy to pull off and set the height.
