Old 21st January 2016, 06:24 AM
mannyo mannyo is offline
Many thanks Adrian. I'll get that done tomorrow
it needs coding so the ecu can reset all the learnt values of the old one. As the battery ages, so its charging time and required curve change, if you put a new one in then this requires the default set of rules. I've recoded the same battery on mine several times to reset the learned values which has resulted in the battery charging better than before.
Manny
Past
