Old 27th April 2015, 11:17 AM
I've got a W12 ACC cluster on a non ACC car, codes properly, CP removed in a same manner and mileage corrected by Polish not Albanian mafia and it's all good.
The only think is that when CC is on, the light for CC or ACC is not coming on, but that's normal with this setup, but CC works just fine.
When you correcting mileage you can't get it 100% right, I've done two D3 with the most sufisticated machine and milage is always around 100miles (+) (-) from what you want it to be.
Old 27th April 2015, 11:19 AM
RenoRanes RenoRanes is offline
There is no maximum mileage for CP removal, but 100KM (~66miles) is the maximum mileage that the dealer can reset the miles so you will need to pay ~£50 to the Albanian mafia or similar.
For part number - best to look on here for options..
http://www.partscats.info/audi/en/?i...tgr=1234567890
and then look on ebay for the part numbers. I have a 2009 cluster in my 2006 and it works fine even though the part number is for later years.
Ok thanks for that, I'll have a look.
I did find one with ACC on ebay from A8Parts but it has 65343 miles on it.
Old 1st February 2016, 08:52 AM
okkim okkim is offline
Hi,
I have PFL A8, and I want to have the wide DIS. I was thinking to flash the current instrument cluster with the facelift wide DIS firmware. Has anyone done it? Is it a crazy idea?
Old 1st February 2016, 09:00 AM
Originally Posted by okkim View Post
Hi,
The worst that could happen is you brick the unit, if that happens ebay is full of them for reasonable money these days and you could always buy my S8 one that I have for sale
https://flic.kr/s/aHskouH8Tt
Old 1st February 2016, 09:04 AM
Hi,
My thoughts are that the hardware is different and would therefore require the correct firmware for all functions to work correctly on the windscreen dis. Is your aim to preserve the original mileage?
Matt
Old 1st February 2016, 09:30 AM
The display area is physically much larger for the wide display. The easiest way is to swap the complete instrument cluster. Then pay the stealers to remove CP.
The mileage is a problem because I have to date not found a way to change the recorded mileage.
Mine was changed by Guy (Daviesbike on this forum) one Saturday. Only took him long enough for me to drink a cuppa. The time consuming bit was visiting Swindon Audi for the CP removal.
Old 3rd February 2016, 09:39 AM
Yes I know that the VISIBLE display area is wider, but as seen in the first photos in this thread, the sides are covered. I don't know if the physical hardware is different, I hope not.
So I would remove the cover, and flash the instrument cluster and that's it I wan't to avoid the CP hassle.
I don't care about the mileage.
Old 3rd February 2016, 12:29 PM
It is, sorry!
Old 3rd February 2016, 06:55 PM
Are you sure? Have you got any inside photos of the pfl and fl clusters?
If that is really true, then I guess that I can forget the flashing
Old 3rd February 2016, 09:05 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
The screens are different sizes.
You can swap then over but that don't work.
But you might be able to swap the the screens over and then flash the firmware.
Could work.
[center]
06 3.0TDI Quattro:
Options:
