Heres a quick guide on how to put a rear door card back on, properly
![]() Firstly, check you have all the parts..... The top two parts are so absolutely fundamental to your interior door handle mechanism that you dont want to even think about starting it you have misplaced one of these... the other items are listed in the order you would install them: 3 screws across the top of the top of the door under the wood trim 1 8mm bolt under the door grab handle 2 small retaining screws to hold the card back at the top corners 2 screws to hold the window switch trim in place Plus, your door card clips.... costing pennies and making all the difference - 8 for a rear door, 9 for a front door: Here is the front view of my door card. The eagle eyed will spot the blinds in the top part, and although it is hard to spot, this is a full leather door card so the double stiching runs the whole lenght of the card in the middle from left to right.... and on the reverse, I've marked the 8 locations for the door card clips. just pop them old (likely broken) ones out, and slide in the spanky new ones.... You will also have to remove the reciprical broken parts still left in the door. They will be old and brittle but will smash out. Try not to push inside the door unless you can help it, and if they do go in, fish around in there to get them out again - you dont want a rattle ! Once ready to fit, we start with the wiring. on a facelift card like this we need to wire in the puddle lights, rear red visibility light, pop the cables through towards the grab handle for the electric window switch, hook up the speaker and remember the tiny connector for the illumination on the door handle... Note also only one speaker to connect here as we have Bose. With non-bose, you also have a tweeter in the rear doors... I know, its odd, I didnt design it... ! Note the old floor mat on the floor to protect the card, use some old carpet / rags etc just to stop it getting scuffed as there is no easy way to do this without putting it down on the floor several times..... Note I've also managed to get a bit more fabric tape in there - just to replace old worn duct tape which has come off, to keep the wires secure inside the door... ![]() You then need to connect up the door handle cable which is a tricky two handed job. The platic C shaped semi-circle goes inside the metal semi-circle of the door handle pull mechanism and the door pull cable slides into that and clicks in. The metal clip is used to keep it in place and stop it falling out. I have no photo as I have no spare hands, but I'm guessing if you're putting a card back on, you took one off so have half an idea what I'm talking about ! Once thats on, the card can be put on - Start at the top by locating the door locking pin into hole and then hook the whole card over the top of door and hang it down. You will then be able to manipulate it into postion above the door cars clips and start to push/bang it gently into place. The clips will snap into position and hold it nice and tight Once that is done, you can put in the 3 big crosshead screws at the top: and then the small screw to the rear: and the other small screw to the front: and finally the 8mm bolt through the grab handle region and you're done. The original wood trim just clips in over the top of the 3 big screws, and the door handle will push in to place after connecting the window switches up. Then the grab handle has a small section underneath with pushes up to mate into place.... Job done... ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
right, i've spent hours documenting relitively small jobs, so in actual fact by the end of sunday I had refitted both rear doors.
I'd also had chance to tidy and sort my garage, and found loads of spare screws. To be specific, they really were spare from other stuff, but because I have put this car back together so 'perfectly' I have used more screws and bolts than I had, as originally some were missing. The result was that the drivers lower dash half couldnt go on at all as all the screws were missing, and I cant begin to count how many screws and bolts David has sent me from a8 parts (big thumbs up, between him and Carl I COULD NOT have done this !! ![]() Anyway, tidy of garage yeilded enough spare hardware to get it done, so drivers side lower facia went in, along with carpet trims. I also managed to get the boot completely sorted. As the LPG conversion went in before i got the car, I had no chance to work behind it. I removed the LPG tank a month ago for this project, so I have now sorted the boot carpet, cut it properly to size, retrimmed the boot making sure every faster is in correctly and I've also got the LPG tank back in and piped up, just waiting 10 mins spare to resolder the electrical connections back on to the solenoid and sender unit. So, whats left to do ? * LPG electrical * Door grab trims for passenger and both rear doors * Fully wet vac the drivers carpet trims (everything else was cleaned and looks fab in comparison) * Buy some rubber mats so my nice clean Audi ones stay that way ![]() Anything not quite right? Yes ![]() 2 problems have crept out of the woodwork: 1) The passenger seat memory which I wired up blind not 100% understanding its whole workings has one slight mis-wire. The white'/green wire which I wired from the passenger memory buttons to the passenger seat to the drivers seat to the drivers memory buttons, shouldnt have gone to the drivers seat. It does on cars without passenger memory so that memory 4 works, but with passenger memory, button 4 should only do the passenger seat and not the drivers. The (rather amusing) result is that when the passenge does their memory 4, they move the drivers seat ![]() 2) The passenger seat goes forward, a lot. I dont think its more than normal, but it goes further than my cabling currently allows. If i move the seat all the way forward, the connector for the passenger seat memory stretches and falls out so memory stops working. Its nothing that extending 10 wires wont fix, but I'm a little tired of soldering this week... ![]()
The million dollar question.....
I've lost count of hours, days, weeks, not to mention ££'s... ![]() Every piece of trim was cleaned before it went back in the car, every piece scrutinised for damage and fixed where possible. Every nut and bolt was re-instated as audi intended, and even door cards were given a new lease of life with new door clips and every single foam seal around the outside rebonded to make sure they were air tight..... Nothing has gone back into this car unless I was happy it was the very best example of that part that could be fitted that I could reasonably lay my lands on (and I have a vast inventory!) At the end of the day I have an absolutely unique D2, something that was never even built at the factory. Its an A8 when alls said and done, and I have the V5 to prove it, yet all its running gear is S8 and all its interior is pure luxury. Its pre March 2001 so will only ever get taxed as 'above 2000cc' and it runs LPG just to makes things cheaper still. Its the most comfortable car I've ever been in, and today driving it from Harrogate to Birmingham something else struck me: Its quiet. Dam quiet. Almost, new car quiet. You know how new cars just ride the bumps and not a squeak, or a murmor or a sound because everything is so tight? Well, thats about where its at. Its done over 150K miles and feels like its done 10. and somehow, thats a really signifiant unexpected bonus. I put all this effort into blinds, and rear seats all for passenger comfort yet i have this unexpected bonus for me, the driver..... .... a brand new car Was it worth it ? Hell yes ![]() ![]() ![]() ![]() ![]() ![]()
Bloomin excelent! You must be extremely pleased with this!
A couple of quick questions; - does all the wood on the doors come out simply by carefully levering it? i assumed i would have to remove the door cards to get the grab handle bits out. - Did you wet vac the alcantara inserts in the door cards? they look spotless! My drivers door card has a couple of marks / scuffs from people getting in and out. I have access to a wet vac as my brother does carpet and upholstery cleaning, but was worried to use it on the alcantara. Edited to add: would love a ride in it, even just to head how quiet mine is! there seems to be a hell of a lot of road noise in mine; it seems no quieter than my girlfriends 1999 polo. hopefully new suspension arms will stop this. Last edited by Mr K; 22nd March 2010 at 10:36 PM. |
2) - Nope, I chickened out on the alcantara ![]()
![]() I've no objection to sharing a bit of cabin space with you for a demo should our paths ever cross, but your car sounds way too noisy - Have you thought about closing the windows? ![]()
Worth every hour and every penny IMHO - your perseverance and attention to detail are second to none - well done Ian!
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten ![]() |
I got the tank back in the boot the other day, but I've only just had chance to sort the wiring....
Its not hard, just 4 wires for mine - 1 pair go to the pressure sensor for how full the tank is, and the other pair go to the solenoid valve that lets gas out of the tank when the car is burning LPG. At all other times, this valve is closed preventing gas escaping. I believe it is also set to trip closed at a certain flow rate, so if you rip a gas line wide open the valve will close instead of letting it all out. The outlet is the thin pipe on the left with the solenoid, and the fill pipe in the larger one on the right. It has a one way valve that opens under pressure to fill and then closes with the back pressure so its safe. Note the substantial bracketry too. LPGA regulations dictate what g-force impact a car should sustain and have the gas tank still anchored in position in the car, and whilst the numbers escape me, its a big number so it needs to be sturdy. One of the problems with the spare wheel tanks is that the A8 has a fiber glass tub which isnt strong enough to bolt to, so it needs metal work fabricating from above and always ends up with an uneven floor.... anyway, I digress.... Photo of the wiring part done: And here we have the job done, covers on and boot looking quite tidy compared to a few weeks ago: and my new LPG control location, now lit up with some green showing we're burning the good (aka cheap) stuff ![]()
Looks like i need to invstigate my road noise issues, Is been bugging me quite a lot, and now i know its not quite right its driving me nuts! If our paths cross, i will definitely be taking you up on that offer of a ride in your car.
Do you have the part number for the door card clips? and is that a special plastic cover on the right hand side of your boot? |
