Cable between amplifier and cylinder 5?
How do I test? Continuity from amps to Coil Pack?
if you can, put some crocodiel clips on with the tester and wiggle the cable.
Or... if it's easy enough to do, swap it to the other side and see if the misfire goes with it. |
Well had a go at tesing continuity and all seemed well. Did some wiggleing and found nothing! Now the prblem is gone. Done 150 miles and nothing going wrong.
Ah.... Maybe you now have the 'engineer fix' like we used to have on the VCR in the early '80s (yes... I am old enough to remember them.. Just!).. They'd play up for ages.. You'd get the engineer out to look at it, and it would behave like a new unit, then as soon as he went away.. bang.. faulty again.
Maybe just some crap in the fuel that was blocking the injector for a bit and has cleared? I would go with the 'heavy right foot' clearance method.. Just boot the bugger for a bit and hope it still works ![]() |
Boot it some more? Ok officer!
Just to close this thread, the problem went away and didn't return before I destroyed the engine.
However, while fitting the new engine at the first fire up I had the same symptoms and it was due to fuel starvation and it threw up the same code! 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - - Intermittent But not the Cylinder 5 code. So check your fuel if you get this code as well. ![]()
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. ![]() Last edited by Conan_the_Librarian; 6th May 2009 at 04:06 PM. |
