Old 23rd April 2016, 11:40 AM
This one seems to be at an OK price
http://www.buycarparts.co.uk/oen/077133471h
Searching by the Audi number 077 133 471 H
The fault could also be with the wiring, power supply to MAF or in the ECU, check out the attached pdf
Old 23rd April 2016, 11:52 AM
I've got a spare MAF which I can loan for a swapover test if you're in the area.
I bought one ages ago to swap over to see if it affected my weird occasional lack of power issues - it didn't. Not actually sure which one is currently in the car.
Edit: Just noticed Norway!
Old 23rd April 2016, 12:20 PM
I have missed that it's Norway as well, try this site: http://www.autodeler.co.no/oen/077133471h Looks like it's the same company and price is about the same as well.
Old 23rd April 2016, 01:20 PM
SilverS8 SilverS8 is offline
Hehe.. Thanks for all info in regards to my problems
I have now cleaned the MAF with Isopronal and it sure looks cleaner, but no difference and the same fault codes.
To eliminate any leaks i have been all over the vacum system and intake related piping with the Quick start gas but no response to that either.
So i know there is not any Airleaks and this only leaves two options:
-Dead MAF
-Wiring problems.
I'll start off with measuring the MAF connectior(Thanks for the PDF Ainar)
Prob will order a new MAF just in case. Stealer wanted 300GBP for a new one..
Since i'm in need of the car everyday i will baby it around until the problem is fixed. Only noticable difference after reaching normal operating temperature, is that it seems be a bit more thirsty(if even possible) So i guess a faulty MAF would cause the car to run rich all the time ?
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 23rd April 2016, 01:34 PM
Thanks.
I see that this unit refers to the same part no as in ETKA, but the Bosch no on the one in my car now and the one mentioned at the Bosch catalogues is
0 280 218 047 / 048
The one in the link refers to another engine code (that i found yesterday but are unable to find today)
Hmmm
2000 Silver S8
Old 23rd April 2016, 02:06 PM
Have gone thru the voltage/earth test and all is the it should be according to the ElsaWin PDF.
Only thing i was not sure if needed to be checked, was the last thing regarding Wirering to the MAF. As long as the other signals i have checked are fine, should that not eliminate any wirering problems?
2000 Silver S8
Old 27th April 2016, 09:34 AM
Update.
New MAF installed today and all is good
2000 Silver S8
Old 28th April 2016, 12:39 PM
Good stuff, its nice when the solution is easy.
