Old 26th April 2016, 08:11 AM
I've never seen one of these pumps before. Certainly seems like a good idea for a quick and easy oil change, but don't you still need to get underneath for the filter?
Looks like the Lidl unit is also available badged as a Clarke unit:
https://www.machinemart.co.uk/p/clar...d-diesel-pump/
Presumably this is technically equivalent too:
https://www.amazon.co.uk/DIESEL-FLUI...dp/B00ZWTOZ4Q/
Us petrol owners still have to crawl under to do the oil filter...
I did buy from from Amazon. Although not the model you've linked, mine is exactly the same as the Lidl unit. Think I paid £23'ish. Amazons customer service came in handy when after 5 months my pump packed in (my fault, I did an hour long heater matrix flush cycle) and Amazon sent another unit free.
Matt
Old 26th April 2016, 08:23 AM
Ah, so it's a petrol/diesel thing? Why is that? That'll explain why I've never had a vehicle with filter up on top though.
I did own a diesel a long time ago (a '91 BX). Don't remember that being any different, but that was an early diesel. I guess we're talking about modern, direct injection diesels.
Old 26th April 2016, 11:20 AM
It'll just be a packaging issue I suspect. It's where it'll fit rather than how accessible it is! The modern V8 petrols won't have space there as there's 2 turbos in that space....
Old 26th April 2016, 07:05 PM
All the BMW petrols and diesels are on top and in a cannister, even since the 1970s. It must just be engineer's choice.
Johnmed, what does your oil filter lid say on it, I can only read half of it - mine is plain/blank.
Old 27th April 2016, 11:18 AM
ulfilias ulfilias is offline
Picked up one of these from Ebay a year or two back as I have a Brabus Smart and they have no oil sump plug so you have to do it this way.
A lot of garages have switched to doing it this way as well, particularly if it's a cheap all in service. Advantage is it's quick and painless. It doesn't however remove all the oil as you have some left in the sump, like getting the last bit of a milkshake through a straw. Also you don't get to check things as much as you would normally, so i'd say do a proper one every once in a while!
Lee
Old 28th April 2016, 06:53 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Lee
I'm not entirely convinced it leaves more oil. From changing mine and checking the dipstick a few times over the last few days to make sure the level was bob on, the oil on the dipstick has been cleaner than after traditional changes.
2007 Mini Cooper S R56
