  #34
Old 27th April 2016, 01:03 PM
A latching relay is a good idea.
You can actually make most regular relays latch simply by using the relay to power itself through it's own contacts. Unlatching is a little more complicated this way if you need a toggle action since you need to break the latch circuit somehow. However it will unlatch, and remain unlatched by default, when powered off.
You can also buy relays with a mechanical latch mechanism, which usually employ permanent magnets. They have the advantage that they require no hold-current but they're pretty rare:
https://en.wikipedia.org/wiki/Relay#Latching_relay
