Old 27th April 2016, 11:18 AM
ulfilias ulfilias is offline
Picked up one of these from Ebay a year or two back as I have a Brabus Smart and they have no oil sump plug so you have to do it this way.
A lot of garages have switched to doing it this way as well, particularly if it's a cheap all in service. Advantage is it's quick and painless. It doesn't however remove all the oil as you have some left in the sump, like getting the last bit of a milkshake through a straw. Also you don't get to check things as much as you would normally, so i'd say do a proper one every once in a while!
Lee
Old 28th April 2016, 01:46 PM
I've never seen one of these pumps before. Certainly seems like a good idea for a quick and easy oil change, but don't you still need to get underneath for the filter?
I was confused too Never seen a top mounted oil filter before. I guess the original thinking was that heavy debris (carbon, metal etc) would settle out in the sump and therefor the filter was placed close to the sump area at the start of the circuit. On older cars, without the the tightly packed engine compartments, the filter could frequently still be accessed from the top.
Old 28th April 2016, 05:42 PM
Those were the days. You could climb in and get both legs in the engine bay on one or two of the old bangers I owned and stand right next to the engine. On my S8 I can barely get an arm in.
Old 28th April 2016, 05:55 PM
Oil pumps still available at our Lidl. I am happy to buy and post if somebody wants one but not available locally but probabaly will not be much cheaper that some online prices considering it's £12.99 for the pump and probably £4-5 for postage.
Old 28th April 2016, 06:53 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Lee
I'm not entirely convinced it leaves more oil. From changing mine and checking the dipstick a few times over the last few days to make sure the level was bob on, the oil on the dipstick has been cleaner than after traditional changes.
2007 Mini Cooper S R56
Old 28th April 2016, 06:54 PM
Johnmed's Avatar
Very kind offer. You also get the long Lidl warranty if that's people's thing.
Old 28th April 2016, 07:29 PM
Thanks - might get that for squirting my ATF in.
Old 28th April 2016, 07:42 PM
Turbo Tony's Avatar
Really good of you to offer. I'll get down to my local Lidl to see if they have any left too. I can't imagine why I might use one, but that doesn't stop me wanting one!
Storytellers Villa Orlando
2008 Audi S8
Old 28th April 2016, 09:09 PM
Turbo Tony's Avatar
No luck finding any at my local Lidl, but it did give me an excuse to play with the background lighting modes.
2008 Audi S8
Old 28th April 2016, 09:11 PM
Johnmed's Avatar
Ha.
