Old 23rd June 2016, 11:45 AM
Joe2.0E Joe2.0E is offline
Brace yourself, genuine pads for a D4 are well pricey.
Worth checking eBay if you have the correct part no.'s
Old 23rd June 2016, 11:58 AM
damtom85 damtom85 is offline
im going for Brembo, i am using there pads for ages and always happy, £55 per axle
Audi A8 D4 4H 2012 3.0tdi Quattro 8spd ZF 8HP55a
Old 25th June 2016, 04:14 AM
kungfupanda kungfupanda is offline
I've recently done the rear pads and discs on my D4. The Pagid ones at ECP fitted with no problems and are performing well. New wear sensors are included with the new pads. Just to confirm on my 3.0 TFSI, there are wear sensors on the rears too. Just on one side though.
Old 26th June 2016, 07:43 PM
Any feedback on brake dust from the pagid or brembo options ?
Genuine pads seem to be mostly made by Ferodo by the way.
Old 14th July 2016, 09:24 AM
velour velour is offline
Hi,
Did you do that yourself - any feedback on how difficult it was. I have plenty of experience changing pads and discs on older cars and wondering whether I can do discs and pads all round myself rather than paying the stealer (£1600)
Old 14th July 2016, 11:18 PM
Yeah I did them myself. I've only done the rears though. I think they're trickier than the front. It's just the same as on any vehicle except you need VCDS or a generic code reading unit to allow you to wind back the callipers. Once the callipers are wound back, you release and remove the sliding pins, remove the caliper and then wind back the callipers with a wind back tool.
Remove the calliper carrier and disc then refit all. You don't need any special tools just the usual tools you'd need for any brake change.
Old 15th July 2016, 12:55 PM
Nice one - thanks very much. Appreciate the info - sounds like I now have an excellent excuse to buy a VCDS as well as saving some money on the brakes!
Old 20th July 2016, 12:06 PM
can you tell , did you input new pad thickness pad values in vcds after you changed them ? if yes where exactly and what procedure you fallowed ?
i ordered set for front and back, pagid pads, all together(front +back) with promotion code and delivery came to £90 from ECP
Old 20th July 2016, 09:25 PM
I used a generic OBD tool to wind back the pistons and then wound them back on again once I'd finished. I know that VCDS asks you to enter the new pad mm thickness but I wasn't asked with the tool I used.
Do a search on youtube on guides to change rear pads on later Audi models. I think C7 A6's have the same procedure.
